ASUS G73SW PC Notebook Logo
A
Anonymous Posted on Jan 27, 2014
I need to know what the primary function of each key 1-12 is.
What is F1 for what is F2 foe etc..
1 Related Answer
Anonymous
  • 6771 Answers
  • Posted on Apr 29, 2012
SOURCE: What do you do if it blinks and you tried pressing f9,f2,f1,etc. and it won't work?
Remove the main battery and try again, if no! sub out the ram one at a time and test each, if still no result! the motherboard has a major issue.
1helpful
How do I get it to go into bios when pressing f2 doesn't work?
Per the internet site, it depends upon the model of laptop. Here are some examples:
Laptops - Access Bios Settings Key
Issue
The most common Access Bios key is the "DEL" button or "F2". This depends on the laptop model, however, and can be confusing if you do not know which key to press.
Solution
Here is a list of laptop models and brands with the keyboard commands / key for accessing the BIOS Setup:
Acer: F1, F2, CTRL+ALT+ESC
ARI: CTRL+ALT+ESC, CTRL+ALT+DEL
AST: CTRL+ALT+ESC, CTRL+ALT+DEL
Compaq 8700: F10
CompUSA: DEL
Cybermax: ESC
Dell Laptops:
Dell 400: F3, F1
Dell 4400: F12
Dell Dimension: F2 or DEL
Dell Inspiron: F2
Dell Latitude: Fn+F1 (while booted)
Dell Latitude: F2 (on boot)
Dell Optiplex: DEL
Dell Optiplex: F2
Dell Precision: F2
eMachine: F2
Gateway 2000 1440: F1
Gateway 2000 Solo: F2
HP (Hewlett-Packard): F1, F2 (Laptop, ESC)
IBM: F1
E-pro Laptop: F2
IBM PS/2: CTRL+ALT+INS after CTRL+ALT+DEL
IBM Thinkpad (newer) Windows: Programs-Thinkpad CFG.
Micron: F1, F2, or DEL
Packard Bell: F1, F2, Del
Seanix: DEL
Sony VAIO: F2
Sony VAIO: F3
Tiger: DEL
Toshiba 335 CDS: ESC
Toshiba Protege: ESC
Toshiba Satellite 205 CDS: F1
Toshiba Tecra: ESC then F1 or F2
Toshiba Notebook [Newer models]:
  • Turn on the computer by holding down the power button while pressing the ESC key
    • The machine will beep, then display:
    • Check System, then press [F1] key.
  • Release the ESC key
  • Press the F1 key
Laptops Access Bios Settings Key
Funtional keys are not working in lenovo
Function keys on many laptops are used as the secondary set and the individual functions of the keys have been shifted to the primary functions. Thus, if you press F1 and things are normal, you would get some kind of "help" But if, as in many laptops, the functions of those "F" keys has been reversed you might get an Internet key, a brightness key, some kind of CD opening key, or whatever the manufacture decided. F2, as another instance, is used to trigger "edit" of the current item....but in many laptops pressing F2 just turns off your wireless signal or dims the screen slightly. In those cases the way to access the expected Fkey functions is to hole the Fn key down (at the bottom left of the keyboard) then press the desired F key. Personally I find it nuts to have reversed an PC age old way but I'm not in charge of keeping people happy so it's not happening.
Hope that helps.
Where do you find the description of the keys for an HP Elitebook 8440p?
what keys do you need descriptions for? if you're talking about the function keys (F1, F2, etc), they have different functions in different applications. what program are you looking for?
Please see attached photo, this is what's
what are you trying to do ?
a bit more information might be able to help you.
IE: what are you doing when this (pop up) occurs ?
and why are striking the F1 or F2 keys ?
Computer keyboards contain keys that, when pressed on their own or in conjunction with another key, provide shortcuts to performing functions, saving time and keystrokes.
On most keyboards, these are the function, or "F," keys that run along the top of the keyboard. "F1" and "F2" are members of this group.
F1 Function Key
Pressing the "F1" function key while you are in an application will bring up the application's help file.
Pressing it when you are not in Windows Explorer or on the desktop produces the "Windows Help" file.
If you are in an application and press the "F1" button along with the Windows button, you will get the "Windows Help" file.
F1 Function Key Combined With Other Keys
"F1" can be pressed with other keys to gain a variety of results and functions.
Press "F1" and the "Shift" key to start context sensitive help, or help for the application.
Use the "F1" key with "Alt" to go to the next field in an application.
Press "F1," "Shift" and "Alt" at the same time to return to the previous field in an application.
To display the Microsoft system information, press "Ctrl," "Alt" and "F1" at the same time.
F2 Function Key Clicking on an icon on your desktop and pressing the "F2" function key will put the icon into rename mode in the same way as right-clicking on the icon and scrolling to "Rename."
F2 Function Key Combined With Other Keys
"F2" when pressed with other keys combines functions commonly found in the application "File" and "Edit" menus.
To copy selected text, highlight the text and press "Shift" with "F2."
To view a print preview of a document, press "Ctrl" with "F2" when in a document.
To save a document, press "Alt," "Shift" and "F2 together when in the application.
To choose the open file command, press "Ctrl," "Alt" and "F2."
I have a WINDOWS LIMIT REACHED MESSAGE AND i WANT TO KNOW HOW TO WORK THE cAMERA iVE SEEN SOME WHERE USE F2 BUT THERE IS no F2 ON THE Eeepad.
You can use function key +F2 or function key +F5 key to turn on camera also make sure camera driver installed make sure camera is enabled in bios too. For that when you power up press F1 or F2 or del key to enter in bios then make sure camera is enabled. Let me know if you need further assistance. Thanks for using FixYa.
1helpful
2answers
I need to know what are the function keys on a keyboard
Hello earthaalford:
Your function keys are usually located on the top row and are labeled F1,F2,F3 and so forth. The function of those keys depends on what program you are currently operating in ie: Windows, Office , Word, Excel or any number of other programs.
Hope this helps, if it did just click the thumbs up.
Sincerely, Peter N.
My Fn key can't function!So are my arrow keys.
you need to dowload the hotkey utlitlity application from vedor site.
I purchased Vaio VGN-ns21m keyboard dont function f1 f2... canc
i guess f1, f2, and all the function keys are given with added fn key in the left corner of the keypad. search for the blue icon with fn in the keypad. that should solve it. press fn along with the key you want to use.
6helpful
Create a barcode for F1 and F2 using Labelview
If you have created your barcodes as "F1" and "F2" you will have to create two Advanced Data Formatting rules with the LS2208 Product Reference Guide. This link will take you to the manual. Print only the barcodes you need from the list below then scan them in the order they are listed:
Begin New Rule
Specific String at Start
F (from the Alpha-numeric section of manual)
1 (from the Alpha-numeric section of manual)
End of message (from the Alpha-numeric section of manual)
Send F1 Key
Save Rule
Begin New Rule
F
End of Message
Send F2
Save Rule
That should do it!
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
