I have the brakes off and it looks like it is in the body what can i do to free it up?
One of the best penetrating fluids I have ever used is a 50/50 mix of Charcoal Lighter fluid and Automatic Transmission fluid, this mixture works far better than just about any "Knock-er-loose" commercial products, but keep in mind it is highly flammable and should not be used around sparks or flame (same as most penetrating fluids). I put the mixture in a multi purpose hand sprayer with an adjustable nozzle (for long distance needle spray pattern and then let er soak....Good Luck...
I fixed it with heat and lots of wd40 and about 2 hours worth of elbo grease
when after I run my tractor for a while it drips oil at the bottom of the govenor
what is the gap setting for points 1953 Ford tractor 8N
