SOURCE: STANDING WATER ON TOP SHELF
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
SOURCE: Water on the bottom shelf of the Refridgerator
I have a whirlpool refrigerator ET21NKXJW00. Getting water in crisper drawers, under drawers, and under bottom of freezer shelf plate. Took off bottom shelf from freezer and took out all the ice. Still getting water in crisper drawers. Help!!
SOURCE: Water collects in bottom of refrigerator and gets in bins
there is a cup in the back wall of the fridge that is the drain pull it out gently and clean it plus take a small hose and blow through the small hole if there is no cup check under the crisper to see if the drain hole is there
SOURCE: water collects in bottom of refrigerator
This is something you will be able to solve, the like below will take you to a detailed instructions and photos of what to do. Let me know if you need more help, Thanks Sea Breeze
http://appliancejunk.com/forums/index.php?topic=22.0
SOURCE: water in bottom of fridge and in crisper drawers
the defrost drain in the freezer is clogged with ice.
empty the food from the freezer, and put through a defrost. you might have to help the fridge defrost with a hair dryer. you may also have to remove the rear panel (inside the freezer) or pending on the model to bottom panel of the freezer.. (usually held in by 1/4" hex screws.)
melt all the ice, and be sure that the drain is clear, and it should work.
