Model #LTF2112AR. First my freezer was freezing but refigerator wasn't cooling and the fan sounded like it was struggling to work so, I exposed freezer coils to make sure no ice build up and poured warm water to make sure opening for air were open. All OK. I put everything back together and the fan noise was gone for 2 days at which time it came back loud like it was going to fly out the freezer but my refrigerator was cold, yeah. I want to make sure that I only need a new freezer fan? Could there be another problem?
SOURCE: Ice build-up around the fan making a noise.
Drain line froze.
Used hair dryer to thaw frozen line, works OK now. 01/07/09
Think the frozen drain line was caused by the light in the refrigerator not shutting off when the door closes, causing excess cooling in the freezer. Poor design on the light shutoff switch, corrected design to make permanent repair
chestnutlee.
SOURCE: Have a Kenmore refrigerator about 9 years old.
its low on freon. may have small leak .you need to put a gauge on to tell for sure.
The noise is water dropping on the hot defrost coil...
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
