SOURCE: ruud achiever 10 inside blower motor burning
Check fan cage to make sure it turns freely. Check voltage to IFM make sure it is correct for the application. Make sure the motor turns the fan cage in the correct direction. IFM will have high and low speed make sure when you change from fan on to auto that the motor changes speed. If you have an amp draw meter check to see when running the motor pulls the amp load it is rated for. Recheck all wiring.
