SOURCE: DH30 Dehumidifier Compressor Does not Operate
I just picked one up at a tag sale, seller said it worked sometimes. Seems to have the same problem as yours. I took the time to tweak all of the connections and then re-soldered the control board with no luck. I finally disconnected the humidity control and it worked fine. By disconnecting the humidity control the unit defaults to it's highest setting and you have to unplug the unit to turn it off. Conclusion so far is that the humidity control rheostat is bad.
Note: Now while running the fan runs continuously and the compressor cycles on and off every 10 to 15 minutes. This may to be normal since the unit appears to be doing its job and I'm not sure how it is supposed to run since a purchased it broken.
SOURCE: LG LD65EL Dehumidifier doesn't work properly
What do you have the humidity level set at on your dehumidifier? The average is 65%. Make sure you do not have it set at 75% because if you do this could be causing it to keep the humidity so high.
SOURCE: LG dehumidifier
I Have an LG Dehumidifier and water has leaked out to the basement floor, it has a hose that drains into the floor
SOURCE: My LG (LHD45ELY6) dehumidifier turns on OK. I hear
Bring it back for warranty and they will send you a new one. The warranty is 5 years for everything. These LG units have a defective design and I was told the evaporator (or parts thereof) rust and leak. My repair store had rows of LGs in for repair. Most people avoid the hassle and buy another brand. If you have the time to call LG, bring it to a repair shop, wait for an assessment, call back LG for a replacement, you'll get a replacement. But you may have to do it all over again next year -- and until your warranty expires.
SOURCE: lg LHD30 dehumidifier not producing water; fan and
there may be no moisture to collect in the air. if you turn up the dial and the compressor kicks in, all is fine
