Plumbing Logo
A
Anonymous Posted on Jan 26, 2014
Shower bottom rollers - Maax Plumbing
Thomas Smithbrother
Level 3:
Top Expert:
  • Master 3,698 Answers
  • Posted on Aug 20, 2014
Thomas Smithbrother
Master
Level 3:
Top Expert:
Answers
3698
Questions
0
Helped
957013
Points
10318
I am trying to replace the cord on a sliding shower screen,
Here are some steps you can follow to replace the cord on a sliding shower screen:
  1. First, locate the end of the cord that is attached to the shower screen. This is usually found at the bottom of the screen, near the rollers.
  2. Once you have found the end of the cord, gently lift the screen off of the rollers. Be careful not to damage the rollers or the track as you do this.
  3. Next, locate the other end of the cord, which should be attached to a tensioner device. This device is used to adjust the tension on the cord and ensure that the screen moves smoothly along the track.
  4. Carefully remove the cord from the tensioner device. You may need to use a pair of pliers or a small screwdriver to loosen any clips or screws that are holding the cord in place.
  5. Cut a new piece of cord to the same length as the old cord, using a pair of scissors or a utility knife.
  6. Attach one end of the new cord to the tensioner device, using the same method as before.
  7. Guide the other end of the cord through the rollers and back to the bottom of the shower screen.
  8. Finally, reattach the shower screen to the rollers and adjust the tension on the cord using the tensioner device. Test the screen to ensure that it moves smoothly along the track.
I hope this helps! Let me know if you have any questions.
Dec 29, 2022 • Garden
2answers
Make image modle BS 6206 door roller need replacing
We don't have parts here. Check the manufacturer's website, Amazon, eBay, and Alibaba.
May 12, 2015 • Home
How do I install the shower door?
Pick it up high into the top rail sliding the rollers into the track. Let the bottom roller fit into the bottom.
Aug 17, 2014 • Plumbing
1helpful
Replace shower door
Hi
You did not mention any additional information about your problem except replacing shower door.However use basic hand tools to complete the job.
Try this following general steps :-
1. Remove the doors by lifting up on one door at a time and then pulling each out. The top of the door has rollers attached to it, and the rollers rest on the inside of the top rail of the frame. Set the doors aside.
2. With your drill, remove the two screws on each end of the top rail, located on the inside of the shower frame. Then lift off the top rail of the shower frame.
3. Use your box knife to cut the caulk on the side and bottom rails of the shower frame. Shower frames are caulked on the outside where they meet with the walls and floor of the shower.
4. Use your drill to remove the screws from the side rails. There will be two screws on each rail, securing it to the shower stall. Then, take the rails out. Remove the screws from the bottom rail and take it out.
5. Use your tape measure to measure the old side rails, top rail and bottom rail. With a pencil, mark the lengths on each new rail. Use your hacksaw to cut each rail. Hold a side rail in the exact location where the old rail was located. With your pencil, mark the screw holes on the shower wall. The new shower frame screw holes may not line up with the old shower frame screw holes. Use your drill and 3/16-inch drill bit to drill new holes if necessary. If the shower walls are ceramic, use the concrete drill bit. If the shower walls are fiberglass, use the multipurpose 3/16-inch drill bit.
6. Insert the 3/16-inch anchors into the holes that you drilled. Put the side rail into position and insert the screws into the holes. Use your drill and Phillips head drill bit to tighten the screws. Place the bottom rail into position and mark the holes. Drill new holes if necessary and install the anchors. Insert only one screw at the end where you installed the first side rail. Lift up the loose end of the bottom rail and slide the second side rail into place. Mark the holes. Remove the side rail and drill the new holes using the 3/16-inch drill bit. Insert the anchors and put the side rail back into place. Insert the screws and tighten with your drill using the Phillips head drill bit.
7. Set the top rail directly onto the side rails. In each end of the top rail, insert the two self-drilling screws until the top is secured to the sides. Insert the tube of clear caulk into the caulking gun. Cut the end off of the tube with your box knife. Caulk the side rails and the bottom rail to the shower walls on the outside of the shower. Re-hang the shower doors by lifting each door and placing the rollers on the inside of the top rail.
Also giving you some links from where you can find a detailed information regarding replacing shower doors.
http://www.diynetwork.com/how-to/how-to-replace-a-shower-door/index.html
http://www.thisoldhouse.com/toh/how-to/intro/0,,214441,00.html
Thanks for contacting fixya.com
Please do get back to us for further query.
Jan 20, 2012 • Home
28helpful
6answers
Where can I find shower door rollers for a maax shower door? Thanks.
amazon is one of the best places for purchasing your shower door rollers. Click here Amazon com shower door rollers and choose the best one (many of them are compatible with maax shower door), but anyway, before order something contact the seller to be sure. There's a plenty of rollers, so take a look.
I hope this was helpful.
enjoy
Mar 05, 2011 • Home
1helpful
Sterling frameless bypass shower doors inside door wont stay closed even though have it on th best option setting to do so
Some times it's possible to tweak a roller track (barely bend) at the proper spot to prevent the roller from back tracking past that spot.
Broken rollers on shower door
The rollers for most shower doors are a stamdard size and are available at most hardware stores. The Bigbox stores might even carry rollers for you specific make and model.
Top Maax Plumbing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Maax Plumbing Expert? Answer questions, earn points and help others
