LG KC910 Renoir Cell Phone Logo
Posted on Jun 03, 2009
2 second ring time then to message bank - need to know how to extend
Hi How do you extend the length of the ring tone. Currently only rings for 2 seconds and then goes to message bank.Hope its not too complicated I'm an old fart and not very technically minded Regards Graeme
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jun 03, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
12132
Points
13
Your cell phone carrier controls that. To you it only goes off twice you should find that the caller hears 4-5 rings before going to voice mail. Either way call "611" and talk to the tech department to see if they can help. Call from a different phone.
2answers
Phone rings twice & then goes to message, I want to extend ring as long as possible
not knowing what phone it is make this hard. It will be in the setup menus but most systems will probably be limited to 6.
I need to extend the length of time my phone rings on incoming calls
Hello, Mary -
I checked the user manual for your Alcatel 3003G cell phone:
https://www.manualslib.com/manual/1150047/Alcatel-Tribe-3003g.html?page=1#manual
I did not find any information regarding increasing the length of time of rings of incoming calls in the manual. So, I thought the incoming rings length of time may be dependent upon your cell phone service provider, Vodafone.
I found some information on a Vodafone Support page:
https://support.vodafone.co.uk/
How to increase the time before a call goes to voicemail?
(Quote)
Your Vodafone mobile is set to ring for 15 seconds before going to voicemail. You can change how long it rings for, choosing from 5 to 30 seconds in 5-second intervals.
To choose your desired ringing time:
  • Enter **61*121*11* on your Vodafone mobile
  • Choose the number of seconds you'd like your phone to ring for, followed by #
  • Press Call
  • A confirmation message will pop up on your screen with your new ring time
For example, if you want to set your Vodafone mobile to ring for 25 seconds, you enter **61*121*11*25#, and press Call. When the message pops up, you'll know it's all done.
Watch this simple video to find out how to increase the time before a call goes to voicemail.
https://youtu.be/rGJNpaaD5z8
(End quote)
Best wishes.
How do you extend the number of rings before answer service begins
Not knowing your phone make & model I can offer advice from my own previous handsets, please Go into your settings menu, select phone setting & then answer setting, choose the longest amount of ring cycles offered, if this is not an option, try selecting a longer ring tone, or downloading a song as a ring tone, which will then play the length of the song making it ring longer... I hope this helps....
How do I extend the ring for an incoming call
Extending your ringing tone You can change the length of your ringing tone by typing the below code into your phone.
**61*(mailbox number)**(number of seconds you want it to ring for)# send You can choose between 5 and 30 seconds. The standard ringing time is 15 seconds.
If you don't know your mailbox number it's just your normal mobile number with '5' added after the prefix. For example, 087 5 1234567.
Apr 12, 2015 • Cell Phones
How do i extend the rings before the answer machine cuts in on my BT6500
Set the answer delay
1. Select Menu, Answer Phone is displayed, press
Select.
2. Press (Calls) until Settings is displayed, press Select.
3.Press (Calls) to highlight either Ans. & record or
Answer only and press Select.
4. Answer delay is displayed, use < or > to display
the number of rings you want (0-9 rings or Time
saver) and select Save. Saved will be displayed.
Set the maximum message length
You can set the maximum length that an answer
machine message can be: 1 minute, 2 minutes or 3
minutes. The default setting is 3 minutes.
Select.
3. Press (Calls) to highlight Ans. & record and press
Select.
4. Press (Calls) to display Max. msg length and then
press < or > to select the length you want and
Billy from Hayward
It is in the owners handbook page 45 get it while the link last
http://www.shop.bt.com/content/uni2/documentation/8h3h/bt6500_user_guide.pdf
How can I set full length ringtone in LG GR500
dial **61*(the your message bank number)**30# this will extend the time it takes for your phone to divert to message bank to 30 secs. If you dont want message bank you can cancel call diverts in your seetings menu after putting in this code and it will still ring for 30 secs. Note: this does not work for Vodafone Australia
Dec 10, 2010 • Cell Phones
How to set message alert tone to ring longer
Most cell phones only play small sound bite from 10 to 20 seconds. I don't know if any play longer.
2helpful
How do i adjust length of time phone rings lg kf310
Call in to Customer Service, listen to prompts for tech support standard customer Service will just Fwd you there, ask the tech that you would like to extend the amount of rings before it goes to your voicemail some providers do it by rings, and i know at&t does it by seconds and if it is by secs good rule of thumb is 5 secs = 1 ring!
2helpful
Ringtone
This is a network specific setting. Type into phone (what iws written in the right box).
Set number of rings **61*YourVoiceMailNumber**N#@
YourVoiceMailNumber = your voice mail numer
N = Ring Time (up to 30sec)
@ = Send/OK button on your mobile phone
Dec 14, 2007 • Nokia 6120
Ring tone
I don't know your country code or vmail quickdial number but try this using those numbers where I say.
Oh firstly if your fone is a prepaid you may need to ring your provider and ask them to extend the ring time.if not this might work
Pls let me know if it does.
** (country code) * (vmail number)**30# and press call this should extend the ring tone to 30 secs.
remember country code & vmail number have to be actual numbers dont try to type in the words and brackets
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
