SOURCE: Tv not changing channels.
This likely has a bad main board.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
SOURCE: My JVC PIP Won't work, pls help!
I was told that in order to view 2 different channels at the same time u have to subscribe to SKYCable and use the digital input instead of the antenna input and the antenna input you will have to use the regular antenna since there is only one tuner in the TV
SOURCE: ilo tv programming problem
get a surround sound system and once you hook up your audio you can then use the surround sound remote..avi in... to control your volume.. and use your direct tv remote to change channels
SOURCE: Sharp Aquos HDTV Failed to receive broadcast
I too have this issue I beleive what is happening is the integrated tuner is not locking on to the channel because of a weak signal and then sending that error message . I am going to replace the cable from the splitter to this tv and see what happens. I have another new tv just installed from that splitter and it has all chanels. Remember to RE- run the locate all channels after anything is done to the cable splitter etc.
SOURCE: remote does not work
Did you drop the remote lately my dog loves the plastic and knarls and slobers on them. Go buy a cheap replacement and try it
