SOURCE: model #ftfb4000fs1 frigidaire front load washer
Just had this problem last week. The problem was the door switch, which made no sense to me since the drum still turned on the other cycles. But the repair shop replaced the ($76!) switch and the machine now works fine.
SOURCE: Yes hello, My washer has a problem w/ draining. It
If water remains in the drum the unit will not go into the final spin. There may be a couple of reasons which I have experienced resulting in your problem. If water remains in the tub the unit will not go into the high speed spin. 1.) A coin or other foreign object is blocking the drain hose. Check the drain hose for foreign objects impeding the exit of the water. Shake the hose and listen for coins or a small object this unit will pass items through the pump into the hose causing blockage. 2.) The Drain hose is not raised above the machine outlet to create a siphon effect. See your manual for proper hose positioning. The hose needs to have a loop in it to work correctly. 3.) The pump is a third possibility which you should hear the impeller spinning during the drain cycle. There is a coin catch after the diaphragm of the pump that looks like a rubber boot that should be inspected for objects if you remove the pump. The pump is about $60.00 and is accessible after removing the front panel under the door. It is easy access from the front and the hose clamps will be the most difficult problem. I have a ratcheting hose clamp tool designed for this type of clamp but channel lock pliers or vice grips will work.
SOURCE: front loading model #FTFB4000FS1 is
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
