Canon EOS Rebel 2000 35mm SLR Camera Logo
R
Rebecca Leann Nelson Posted on Jan 25, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Adding a lens to my camera
I would like to add a zoom lens to my camera. I no nothing about lenses. I bought a set but they do not fit. Is there an adapter that I may use? What do you recommend?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Canon Master 102,366 Answers
  • Posted on Jan 25, 2014
Canon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10443774
Points
622693
Since you didn't give any details about the lenses you bought, it's impossible to say whether there are any adapters available.
In general, any lens with a Canon EF mount will fit the Rebel 2000. This includes lenses made by Canon (obviously), as well as lenses made by third-party manufacturers, many of them make lenses with Canon mounts. In addition, there are some adapters available for some other mounts.
Harrie
Level 3:
Top Expert:
  • Canon Master 6,746 Answers
 Harrie
Canon Master
Level 3:
Top Expert:
Answers
6746
Questions
0
Helped
1285945
Points
83153
To be sure you can use the lens, buy a Canon EOS lens. The plastic ones, can be cheap. I bought my last lens 28 - 80 mm, couple of months ago, for 5 dollar. and a working EOS 500 was connected for the same price. (lens and camera are still in good working order) Don't try other brands, because even when you find a convertor, it could be the lens will only work on manual focus.
1 Related Answer
Anonymous
  • 423 Answers
  • Posted on Mar 26, 2009
SOURCE: ordered lens for Canon T70 camera
Hi there and welcome to FixYa.
Check on the box. Your camera has an FD mount. The lens you need to use also has to fit the Canon FD mount. If the lens you received is not an FD mount lens...send it back.
Thanks for coming to FixYa.
Rob
1helpful
Does this lens have a t-mount?
If someone is selling this "old" lens, you should ask him (her) what kind of mount it has. These lenses are made for different brands. Most of the time you also can buy an adapter to fit it on your camera. No problem most adapters don't give trough the AF info, because this lens is an manual focus lens. More interesting is to know if your camera can work with manual lenses. Because most of the time you also have to set everything by hand. Like aperture shutter time and so on. So check the manual if it can, to avoid disappointment after you bought this thing. Also read what others think about this lens.
Need lens (up to 200)
Lens needs are determined by the type of photography one shoots. Example, for my needs I use three prime lens, 35 mm, 50 mm, and 100 mm. Sold all my zoom lens purchased primes.
The question is what are you attempting to capture? On a zoom lens look towards a constant aperture, not one when we zoom the aperture changes.
Cordially
1helpful
Promaster lense fits nikon D3000 but camera says lens not attached
Promaster makes many different lenses. Some of their older lenses do not have the electronics to communicate with newer digital cameras, and you have to shoot in Manual mode. Could you tell us which lens you're asking about?
Nov 30, 2012 • Cameras
2helpful
What size lens do i need for this camera?
You just need any Minolta AF mount lens. Sony Alpha lenses also physically fit as Sony inherited the Minolta lens mount when they bought the company, but as they are a later development not all will be electronically compatible.
The size of the lens depends upon the focal length of the lens and you choose that according to how wide a field of view you desire. Typical lenses are 28 and 35mm wide angles, 50mm "standard" (approximately the same perspective of how the human eyeball sees images), 70 to 90mm short telephoto lenses (a narrower perspective and very good for portraits) and higher numbers are narrower perspective telephoto lenses for viewing increasingly distant objects. In practice, the available lenses will be incorporated into zoom lenses which incorporate a seamless range of focal lengths within one single model. The word "zoom" reflects the fact that you can seamlessly change from say 28mm wide angle through to 80mm short telephoto and every single setting between them
Any zoom which starts at less than 50mm and finishes in the short telephoto range is called a standard zoom and is the lens that most autofocus cameras were supplied with. The next most common size will be something like a 70-200mm which is a telephoto zoom (or tele zoom) and takes you from a portrait lens to a genuine 5x magnification telephoto. You may also find so-called "super zooms" which do the whole job on one, for example 28-200mm. but the more jobs a single lens tries to do, the bigger and bulkier it becomes and the image quality deteriorates due to poorer contrast and greater image distortion at each end of the zoom range.
This is not an exhaustive answer, as there are entire books on the subject, but hopefully it's been of help to you.
Please take a moment to rate my answer or to add a comment if my answer has left you with unanswered questions which need to be resolved before you can rate my reply.
I have a Quantary zoom lens 28-90mm "for Minolta AF". It fits my Sony alpha350 camera, but the camera does not recognize it - says there is no lens. What's up?
Fitting is not always the solution. It is the software which recognises the hardware attachements. Either upgrade your camera software or use only the manufacturer recommended add ons. [email protected]
2answers
Pentax mz-7
Yes the mz-7 Definitly uses a K mount.
Lens
Sorry, the mounts of Minolta manual focus lenses are different than their auto focus series. Sigma, Tokina and Tamron all make compatible zoom lenses to fit the Maxxum series cameras
Wide-Angle Lense Fuzziness
That's completely normal for those cheap wide angle add on lenses. There good for a little fun but nothing serious. I bought the lens kit for the Kodak DC3400, probably the exact same lens. The telephoto in that kit was actually pretty reasonable though.
Top Canon Photography Experts
old marine
old marine
ZJ Limited
ZJ Limited
Are you a Canon Photography Expert? Answer questions, earn points and help others
