Symbol PDT 6800 Portable Terminal Logo
C
Carlos Gamez Posted on Jan 25, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Software PDT6800-NOS64000 Hello, I can't build the .hex files to upload to the terminal PDT6800, the terminal only has 640 Kb in memory, where I get the software needed to fix the problem and put in working the terminal. I found software but is for the same model with 1 Mb memory and this is greater than the 640Kb that I have in the terminal. I tryed to upload that .hex program in the terminal, but don't load flashdisk and the like (not enough memory) It work with OS dr dos Caldera. Thanks Carl
adam adms
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Master 829 Answers
  • Posted on Jan 25, 2014
adam adms
Master
Level 3:
Renaissance:
Answers
829
Questions
0
Helped
69971
Points
2193
Try to increase the memory
2answers
This copy of windows did not pass genuine windows validation pls help me
Hello !
to fix problem
1- go to Notepade or blocknote
2- copy and paste this code
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\WPAEvents]
"OOBETimer"=hex:ff,d5,71,d6,8b,6a,8d,6f,d5,33,93,fd
"LastWPAEventLogged"=hex:d5,07,05,00,06,00,07,00,0f,00,38,00,24,00,fd,02
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion]
"CurrentBuild"="1.511.1 () (Obsolete data - do not use)"
"InstallDate"=dword:427cdd95
"ProductId"="69831-640-1780577-45389"
"DigitalProductId"=hex:a4,00,00,00,03,00,00,00,36,39,38,33,31,2d,36,34,30,2d,\
31,37,38,30,35,37,37,2d,34,35,33,38,39,00,5a,00,00,00,41,32,32,2d,30,30,30,\
30,31,00,00,00,00,00,00,00,00,0d,04,89,b2,15,1b,c4,ee,62,4f,e6,64,6f,01,00,\
00,00,00,00,27,ed,85,43,a2,20,01,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\
00,00,00,00,00,00,00,00,00,00,00,31,34,35,30,34,00,00,00,00,00,00,00,ce,0e,\
00,00,12,42,15,a0,00,08,00,00,87,01,00,00,00,00,00,00,00,00,00,00,00,00,00,\
00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,94,a2,b3,ac
"LicenseInfo"=hex:9e,bf,09,d0,3a,76,a5,27,bb,f2,da,88,58,ce,58,e9,05,6b,0b,82,\
c3,74,ab,42,0d,fb,ee,c3,ea,57,d0,9d,67,a5,3d,6e,42,0d,60,c0,1a,70,24,46,16,\ 0a,0a,ce,0d,b8,27,4a,46,53,f3,17
3- then save this file by this name Xp.reg
4 -
After you save the file run it and restarts your Pc
Good luck
When it boots up it goes to a d prompt and error message says command or file name not reconized
I've seen this fault many many times. Its either a software fault which can be remedied by reloaded the software lwp.hex, udp.hex and the application or a hardware fault where the flash chips are not being accessed correctly.
So basically try and reload, if that fails it will need to be repaired.
If you need any more help then please do not hesitate to contact us:-
[email protected] or TEL +44(0)1202 620955
http://www.biastechnology.com/
2helpful
QuickBasic compiled program run on Symbol PDT6100 or PDT6800?
You need Manufacture provided Software Devepment Kit. I cannot attach a file here so let me know if you still need this.
You can always contact me directly [email protected] or 630-622-2024 toll free 866-271-9891 Ask for Andrew
Hello, my handheld symbol pdt6846 need load SLOADI to cingifure, i need to know how
The PDT6840 has 3 files loaded into it at any one time LWP.HEX, UDP.HEX and an application. SLOADI comes up on the screen during boot. You may require reloading of the software to enable this function again.
or TEL 01202 620955
1helpful
2answers
I am using utorrent..i want to know if how can i run it faster than usual speed of it..any idea? tnx!
The only way to make a torrent run any faster would be to increase your upload speed within the program. Torrents usually work on a speed ratio, meaning if your upload speed is set to 10 KB, your download may be capped at 200 KB.... if you up it to 20 KB upload then you'll max out at 400 KB down..
But, most of the time this isn't affecting anything, especially in utorrent. The most likely scenario is that the people you are getting it from have very slow connections or have many people getting the file at once. That's the downsides of torrents, it can take days or even weeks to download some files.
How to connect the PDT6800 to computer?
Product manual can be downloaded here
http://www.barcodesinc.com/symbol/pdt6800.htm
Symbol Pocket PC ppt2846 software install
see chapter 12 of the reference guide
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5093102apdf&sliceId=&dialogID=76630451&stateId=1%200%2076626512
use TCM to configure the software you require to upload (and where it goes)
then use the hex loader to upload to the terminal.
30helpful
3answers
MOTOROLA RAZR V3M MP3 DRIVER/UTILITY DOWNLOAD
Hi
driver releated problems are easy to solve, thanks to this Driver Update tool.
Wish you best of luck
Greg
Top Symbol Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
