Question about FibaTape Drywall Crack Repair Tape Fibrglass 6" x 20 Ft
Drywall repair need to fix drywall
    New Friend:
    Problem Solver:
  • 13 Answers
Just saw your question but no answer. Sorry about the repair on the glass tape. Crack are pretty common with mesh tape, especially if the mesh was covered with premix all purpose compound. Mesh tape should be covered with setting type compounds. More info can be found on the tapebuddy.net how-to manual. They cover the reasons for the different compounds.
Posted on Dec 11, 2014
  • Ron Morton Feb 19, 2015
    Brook, you might be right on calling someone to help as there's no comment on the drywall ability of this person. It sounds like the cracked drywall joint was seamed by using normal compound to cover the mesh (not good) but the question is not explained well. We don't know if the crack in on the ceiling or wall. These joints can be repaired by applying new paper tape after removing the old mesh tape sanded down to the drywall surface. Use a TapeBuddy system to run the run the new tape. No bubbles or blisters in the finished taping project. Mike should try one of these tools as well. These tools work great in hot climates! Tape goes on flat and tight against the surface. Let dry and top coat to finish. If one seam is bad, chances are high that there are more. Sorry to hear this but you're not alone on this one.
  • Ernest London
    Ernest London Oct 18, 2017
    That sucks that your drywall needs to be fixed. What exactly is wrong with it? My friend is actually in the same boat, because he just found a lot of holes in his drywall. I know there are some contractors who specialize in drywall repair, have you tried to contact any of them to take a look? Good luck! http://www.ivowallexperts.com/Drywall_Se...
6ya staff
SOURCE:
How do I hang an object using drywall anchors?
hi there.
Sink A Self-Drilling (Threaded) Anchor
  1. Mark your hanging point with a pencil.
  2. Tap the pointed tip of the anchor into the wall with a hammer.
  3. Once the tip is in the drywall, with a screwdriver, screw the anchor in until it's flush to the wall.
Fix-It Friday: Anchors Aweigh! How To Put Anchors Into Walls
womenyoushouldknow.net/fix-it-friday-anchors-aweigh-how-to-put-anchors-into-walls/
How to Install Drywall Anchors to Hang Heavy Stuff on Your Walls
How do hang an object using drywall anchors Google Search
Nov 28, 2017 | Drywall
Tip
Cutting Drywall Like a Pro
Cutting drywall is one of the more easy cuttings that you will do when remodeling your house although you hear all kinds of horror stories of people making huge mistakes and having to re-hang drywall or use exorbitant amounts of putty to fix mistakes. Following just a few simple tips you can master the task of cutting drywall.
Most of the cuts that you will be doing will fall under the category of score, snap, cut. Because dry wall is fairly easy to cut, for a majority of cuts you will just need a scoring knife with just enough pressure to cut the paper and then you will be able to snap the drywall then you have to cut the paper on the back side and you are done.
For the major cutouts that you will be doing like doors and windows, the best way to go about doing them is to measure and cut the boards before you hang them. Its best to have someone help you hold the board in place.
There are two main types of saws that you will use a drywall rip saw and a keyhole saw. They each have their purpose and they should only be used for the purposes that they are meant for. The keyhole saw is for small cuts like holes for light fixtures, outlets and switches while the rip saw is for cutting drywall down to size like for doors and windows.
Once you have mastered the basics of cutting drywall you will be able to do more advanced home repairs and will spend less time worrying about cutting out pieces of drywall.
on Jan 23, 2014 | Drywall
Tip
Minor Drywall Repairs
<span>It takes about 4 days for a good patch to be made. You can buy the materials in small quantities at the hardware store, so it won't cost much at all for a small hole, and a little more for a larger one.<br /><br />For a hole smaller than a tennis ball, you can press newspaper crumpled loosely into a ball into the hole, as much as you need, to build the hole up to just below the surface, then cover with overlapping layers of drywall mesh tape. The directions for a larger hole follow, and you can skip the first parts of it if you do not need them (if you are using the newspaper method.). With this method (newspaper) the most important part is to remember that the first coat of spackling is just to anchor the tape and bridge the repair, no more.<br /><br />The easiest way to repair a larger hole in wall board:<br />1. Cut a piece of new wall board larger than the hole you want to repair.<br />2. Take your wallboard "patch and hold it over the hole. Draw the outline of the patch on the wall.<br />3. Using a drywall saw, cut out the outline of the patch on the wall.<br />4. Cut a piece of wood longer than the hole is tall, by about 4". Measure back from each end 2".<br />5. Start a drywall screw 1" above the patch outline, centered. Align the wood in the hole with the lines you made on it at 2" back from the ends. Screw the drywall screw into the wood. Do the same at the bottom. You'll want the drywall screw to be below the surface while trying not to break the paper surface of the drywall.<br />5. Fit your patching piece into the cavity, and, depending on how large the hole is screw through the patch and into the wood with one or two drywall screws.<br />5. Using self-adhesive drywall tape, tape the crack around the patch, overlapping at the corners.<br />6. Use pre-mixed drywall spackling with a 4" putty knife to apply the first coat of drywall spackling to the patch. The aim here is to secure the new drywall to the old, so you need to use the putty knife to press the spackling into the crack, and lightly coat the drywall tape. If your screws that were used to secure your wood to the back of the old drywall are outside of the tape, press the spackling into the screw dimples as well. If you hear a "ticking" sound as you pass over the screws with the spackling, the screw isn't set deep enough. Give it another turn or so, until you don't hear it tick when you pass over it with the knife. Let all of this dry for 24 hours. Clean your tools, and dry them.<br />7. The next day, sand any burrs that stick out, but sand lightly, trying to taper the patch out onto the old wall. Don't be too particular, as there is still a ways to go. Using the drywall knife and spackling, re-coat the patch, blending more onto the wall, and leaving a little more material in the mesh of the drywall tape. The cracks should be refilled, as they'll have shrunken in overnight, so this is all done at the same time. Don't over-work it, just give it a good coating, and leave it alone. The screws that you previously spackled will get another coating at this time as well. You're done for the day, clean and dry your tools.<br />8. The next day, lightly sand the burrs, again feathering a bit onto the wall. Try to remove the dust from sanding with a dry cloth, lightly brushing the patch and wall. This should be the final coat today. Lightly apply your spackling, feathering it out onto the wall. The aim here is to make the finished repair invisible to the eye, so feather out onto the wall at least the width of your blade, if possible. You can fill the screw holes again as needed, feathering the spackling out from the screw dimples onto the patch and wall. Done for the day. Clean and dry your tools.<br />9. Day 4. Sand the patch, feathering out from the patch and across the patch. It should appear relatively flat to the eye, with the cracks and screw holes filled and feathered. No tape should be sticking out. It will all appear smooth. It is ready for matching paint.<br />Hope that this was helpful.<br />Best regards, --W/D--</span>
on Feb 03, 2011 | Plumbing
How to fix 1 inch holes in drywall
many home improvement stores sell partial sheets . then you cut a plug the right size and spackle it in place .
Apr 06, 2016 | Drywall
My 2012 wall air condioner is leaking. How do I fix this and repair the drywall?
It sounds like the drain line is plugged where it goes outdoors, so water is backing up inside the unit until it spills over indoors. Clear the drain line.
You may need to cut a section out of the drywall where it's been damaged, then get a matching piece of new drywall to replace it. If you can cut down the centers of two studs, all the better - then you can screw the new patch directly to the studs on both sides. If not... at least leave yourself a couple of inches of drywall to stitch to - you can do that by screwing small pieces of plywood to the existing drywall, overlapping the hole. Then you can screw the new drywall patch to the plywood.
Next is your adventure in taping & mudding & sanding the drywall to finish the patch. Last, paint it to match the rest of the wall... or repaint all of that wall, including the patch. No need to paint adjacent walls, if your color matching is pretty close.
Jul 26, 2014 | Samsung MH052FNCA 18000 BTU High Wall 410A...
Paint bubbles on drywall
It's been almost 10 months since the question was posted so how does it look? Most bubbles appear under the drywall tape or could be from primer / paint being rolled over drywall dust. Tape bubbles don't go away. These need repaired by cutting out the bubbled tape and filling in with compound. Tape bubbles can be avoided by using a TapeBuddy taping tool. This tool applies compound directly to the tape so there are no dry spots under the tape. Hope this helps.
May 05, 2014 | Drywall
Drying out wet drywall
I'm assuming your talking about drywall that was wet during a flood of some type? Recommend you remove all damaged drywall and using a straight edge and a utility knife this can be easily accomplished. After you cut and remove the damage, remove all screws or nails from the studs giving a good surface for the new drywall that your going to replace the damaged stuff with. Get that done and we can move onto taping and drywall compound repairs. Hope this helps.
Mar 16, 2014 | Tools & Hardware - Others
Fixture for curtainrail wentthroughplasterboardbig hole now help.me fix please
Hi, W/D here.
Feb 03, 2011 | Washing Machines
FibaTape Drywall Crack Repair Tape Fibrglass 6" x 20 Ft Logo
1,837 people viewed this question
Top FibaTape Drywall Experts
ray gallant
John Donghia Jr.
John Donghia Jr.
Are you a FibaTape Drywall Expert? Answer questions, earn points and help others
