I have just bought a Lexar Multi-Use 16GB SDHC card to store GB's of photos. When transferring from the Verbatim TB to the SDHC card it tells me to remove the write protect. I have moved the white "toggle" from the one side to the other but with no effect. It is still write protected.
You can remove the right protection from the computer you use to create the right protection, if you want to use diferend computer that's impossible but same you can go to start and type CMD the comand prompt once the (CMD) folder will open, type (discpart) another (CMD) folder will open type list disc that is going to highlight all the disc on your computer or laptop, now type select disc and exact number of the flash drive if it's 1 2 or3 and hit enter it will select exact number with the flash drive, now attribute clear readonly and enter, now it will says attribute successfully, now type exit to see changes remove the flash drive and plug it back done
SOURCE: Bought myself a 14 in 1 card reader to read my new
Are you using software that came with the reader? Maybe that is the problem. Are the correct drivers installed? Check the device manager and make sure it does not show a problem device. Are you using my computer and clicking on the removable device? Does the card work ok in other computers or devices? Is your computer only USB 1.0 and the card reader requres USB 2.0? Are the USB 2.0 drivers properly installed on your computer? Try removing the software and drivers, re-boot, and just install the drivers and not the software.
SOURCE: how to remove the write protection on a verbatim micro sdhc
click start click to open on my computer you should see your micro sdhc drive E: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your micro sdhc usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
hope this helps you
SOURCE: how to remove the write protection on a 8 gb sdhc from verbatim
click start click to open on my computer you should see your micro usb drive E: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
Right click the icon of your micro usb drive (It should be E:/ or something)
Click permissions
hope this helps you
