VIZIO 42 CLASS RAZOR LED SMART TV M420KD I am reposting this question. This is not a projection tv. Picture was fuzzy for a few days, then suddenly heavy green ghosting on people and throughout the entire screen. There is also a thin white vertical line on left side of screen. Tried to reset factory settings and it was worse. The sound is fine, just the picture is very green and distorted.
Hi Charlene,
please try with video input from any device,and i think you are using local antenna and it has gain problem or your tuner section of the tv is not working correctly.
if distroted pictures comes with video input signal it is video amp and processing unit problem.
you have to go for repair shop for fix that.
regards,
nuwan
Testimonial: "Sorry but I thought that I said it is not a projection tv. This is a Vizio razor led smart tv m420kd. I do not use local antenna. I have unhooked my cable box and just tried antenna. Also tried to just use wi fi and the picture is the same and getting worse. Thank you for your imput."
SOURCE: Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
SOURCE: 57H81 projection tv has very wiggly picture.
This is the Hyper Module that needs repaired. There are several small sm caps that dry out in this model. It's the module standing up to the right covered by a can as we call it. I really don.t recommend you trying to repair it. One slip and that module is done and you can't by a new or rebuilt one anymore. Please let a repair center look at it and do the work. You won't regret it.
