New Dell 2020 / wall mounted. first time turned on ... walked away, someone put in a password, logged on then walked away ..... no idea how to reverse ...
Press F12 on startup to get the boot options, select yr DVD/CD drive and this will reset your password.
Alternatively find a local PC repair guy. If they're any good they can do it in 5 minutes for a nominal charge. If they try to charge lots of money walk away. It's an easy fix if you know what you're doing.
It is possible that on accident you are hitting a extra key or have caps lock on. If not and you have checked a few times, someone could have changed your password. To check go to the email website that you use to log in to your facebook, such as yahoo.com or gmail.com. After you log in check to see if a message about a facebook password change has come through, if not have facebook send you a new password so you can get back in and then cahnge your password to something new so it doesnt happen again. Becareful using your facebook on other public machines, make sure to log out of them before walking away.
Here are a couple of tests
1.Did you check to make sure your "caps lock" button is not on?
2.Could someone have got your password and changed it?
These are the obvious questions, however, you can always, try to log on to facebook, then click the "i forgot my password" button, and you will be walked through to either answer questions, or sent a new password.
Hope this helped!
Minimize everything and right-click on desktop; go to screen saver and uncheck the "on resume, password protect", or just adjust the time you want your keyboard to stay unlocked and keep the box checked.
Reverse lamp switch wiring or switch itself is defective. Mounted on trans. Run slector lever over reverse with someone watching. the back.If yhey flicker the switch is bad. Work it several times sometimes helps .
Something or someone has changed the system configuration from a Workgroup to a Domain. If you have no idea how this occurred, you will likely have to re-install Windows
tianalt' This question is a possible security problem for someone else if I do not have proof of your ownership. I am sorry. I do not want to upset you.
Check to see if reversing the plug takes away the buzz. Some times turning the plug over in the wall socket i.e. reversing polarity, will remove the buzz.
wall mounts are designed to fit most every unit. some have locking tabs on the bar that stops them from bouncing off during an earthquake. it makes it harder for someone to walk away with your set. try frys electronics depending on where you live, or hometech.com, or radio shack. other home electronics stores have them. even wallmart. good luck mark
