The remote for my Hisense tv stopped working. Only the Youtube button and Netflix button work. The volune, input, menu, and all other buttons on the remote do not work and now my tv is stuck with no volume. Cannot use the channel change button or power button. The light on the Hisense logo on the tv isn't on either. Help
To do a factory reset; you should enter its service mode option. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy.
Service mod entry, adjust and exit procedure to many popular brand TVs are given in detail.
SOURCE: INPUT GOING CRAZY
It could well be the accumulation of dirt/dust behind the buttons causing them to stick. If you are able to carefully remove the board that the buttons are located on and use a cleaner that will de-grease at the same time. Be sure that everything is dry as can be before re-assembling and then check if the problem persists. If you are not capable of doing this trust a competant technician. Hope this helps.
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
UNPLUG THE SET FOR A WHILE AND PLUG IT BACK IN TO SEE IF IT WILL REBOOT-sounds like a microprocessor problem and could have been caused by a power outage etc.
Its main digital board should be troubleshooted. Visit the site named 'Electro-help' for
more details. Click this link. View it in
"Timeslide" or "Flipcard" option, which can be selected
from the drop down box menu by the [Sidebar] tag, at the top left corner
of the display window. You can also
click the [Home] tab to see the latest updates. It will make search
easy. There are more than 1350 posts to different brand TVs now. Pull up older
posts there.
