Question about Hampton Bay Building Materials
Laminate Flooring What can I use to seal laminate flooring?
    New Friend:
Need more information.
Read our guide on laminate floors
Posted on Feb 20, 2014
    Novelist:
    Habit-Forming:
  • 100 Answers
Sealing the laminate flooring is easy. Take any clear or yellow wood glue to seal the crack. A caulk or wood putty will be also fine to fix the gaps. Take a thick coating of glue in a spoon and apply to this surface, aiming for even coverage from one end to the other. You must apply enough glue, else the floor may not hold up long under constant foot traffic.
If the gap is huge, use floor gap fixer. When the laminate floor gaps are not repairable, you can simply replace the floor.
I personally prefer hardwood floor, as hardwood floor repairing is more easy. After repairing with hardwood floor refinishing, the floor will look like new.
Laminate flooring also has advantages over the hardwood flooring. But hardwood floor is more durable than laminate floor.
Posted on Jul 23, 2019
2 Suggested Answers
6ya staff
SOURCE:
jadapinks
SOURCE: Dirty laminate
Getsome hot water and and detol/bleach 1 or the other and mop your floor where its dirty
Posted on Sep 14, 2013
Does the bamboo flooring installation process differ from laminate flooring installations?
Bamboo flooring comes in three styles, solid, engineered, and click lock. The click lock and engineered are virtually designed just like laminate flooring, the only difference is the installation. Engineered has to be either nailed, stapled or glued down (depending on the subfloor, whether it is concrete or wood). The click lock is a floating floor and is installed the exact same as laminate flooring. Whether its on wood, or concrete it doesn't get nailed or glued at all.
Sep 28, 2015 | Building Materials
Which is better between hardwood floor or laminate floor??
I think.. hardwood is much better than laminate wood flooring, but each type of flooring has its advantages and disadvantages. Hopefully this article can help you to choose the floor you want.
Main Differences Between Hardwood And Laminate Flooring
Jul 31, 2015 | Building Materials
Is Pergo the same as laminate?
Pergo is the name of a specific manufacturer of laminate flooring
make sure you follow all the instructions in the package when installing a laminate floor. They all have slightly different methods for success.
Jun 29, 2014 | Dream Home - Ispiri 12mm Americas Mission...
Longview pecan reviews
always use laminate flooring cleaner or even windex will work in an occaisional bind. (Vinaigrette belongs in your salad.) Vinegar and water build up over time.
Jan 12, 2014 | Hampton Bay Laminate Samples: Longview...
Laminate flooring repair
If it's older laminate it will be glued together making repairs impossible.
Apr 06, 2013 | Vacuums
Dogs and hampton bay laminate flooring
Yes, you can count on that. But if you leave urine uncleaned constantly.... flooring should be the last of your problems.
Apr 03, 2013 | Hampton Bay Laminate Tile & Stone...
What are the advantages of laminate flooring over hardwood flooring?
First, you can get the exact visual design that you wanted and it will cost you considerably less. Second, laminate flooring can be installed above and below the grade unlike hardwood flooring. Moreover, the laminate flooring is installed without using any nails or glue which make it much easier to it yourself. Furthermore, laminate flooring is extremely durable, easy to maintain and can be replaced easily.
Feb 06, 2013 | Building Materials
How much laminated floor should I get?
You get an idea on how much laminated floor you will need by measuring the length and the width of the rooms that you plan on installing laminated floor, multiply the length by the width and add 10 percent for installing errors and variation in floor design.
Does laminated floor look like real wood?
Absolutely, using photographs, laminates lock in the realism of hardwood strip. Nowadays, laminate floors offer an unparalleled level of realism making the floor look like real wood.
Jan 10, 2013 | Building Materials
How do I remove a hardwood floor polish safely from a laminate floor
www.hard-wood-floor-cleaners.com
and select the best chemicals and use for your hardwood polish laminate flooring.
God bless you
Aug 02, 2012 | Vacuums
Building Materials Logo
555 people viewed this question
Top Hampton Bay Building Materials Experts
Lawrence Oravetz
Tom Chichester
ray gallant
Are you a Hampton Bay Building Material Expert? Answer questions, earn points and help others
