Tip & How-To about Drywall
Cutting drywall is one of the more easy cuttings that you will do when remodeling your house although you hear all kinds of horror stories of people making huge mistakes and having to re-hang drywall or use exorbitant amounts of putty to fix mistakes. Following just a few simple tips you can master the task of cutting drywall.
Most of the cuts that you will be doing will fall under the category of score, snap, cut. Because dry wall is fairly easy to cut, for a majority of cuts you will just need a scoring knife with just enough pressure to cut the paper and then you will be able to snap the drywall then you have to cut the paper on the back side and you are done.
For the major cutouts that you will be doing like doors and windows, the best way to go about doing them is to measure and cut the boards before you hang them. Its best to have someone help you hold the board in place.
There are two main types of saws that you will use a drywall rip saw and a keyhole saw. They each have their purpose and they should only be used for the purposes that they are meant for. The keyhole saw is for small cuts like holes for light fixtures, outlets and switches while the rip saw is for cutting drywall down to size like for doors and windows.
Once you have mastered the basics of cutting drywall you will be able to do more advanced home repairs and will spend less time worrying about cutting out pieces of drywall.
