It will start if i hold the switch bac
If you need service manual, its available here
https://big-manuals.com/products/john-deere-models-425-445-455-lawn-and-garden-tractor-repair-manual
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
SOURCE: john deere stx 38 with black deck, will not do
I see this problem not as an electrical but a seize problem. Since I can't be there to inspect I am relying on your discription of the problem. I would go first to the place of the problem. If this solenoid goes up to disengage and down to engage ,or the opposite, this is most likely your problem area. It may be seized in the disengaged position therefore not allowing the blades to get spinning. Disconnect the belt and try to turn unit by hand, if tight or completely stuck use penetrating oil on pulley shaft.If shaft loosens up and blades engage this was the problem. Is there a grease fitting anywhere in the area?I hope this at least gets you started in the right direction. GOOD LUCK.
SOURCE: John Deere lt 133 wiring diagram
Hope this page will help
http://www.google.ca/search?ix=sea&sourceid=chrome&ie=UTF-8&q=John+Deere+lt+133+wiring+diagram
