The oven is stuck with a nonflashing 00:00 with a red "Delay" written. The model number is MGS5752BDS. How can I fix this? I keep kitting "cancel," but I'm stuck on this screen and can not bake.
SOURCE: Maytag MER6772 - Oven bake element not working even after replacing it.
To find service information for your Maytag Model go tothis link
http://www.servicematters.com/
When on this site, click on Maytag Historical Service Library.
Then click on Maytag Service Library.
Click on term and conditions
Click on Literatur by Model
Enter Modle number MER 6772
Clck go
You will be able to print or download the service manual for your model
Your problem may be the bake relay on the clock or wiring.
SOURCE: Maytag Gemini Stove Code F1-4 (bottom door won't open)
F-1 error is a Temperature Runaway. It Maytag's way of letting you know that oven overheated. Nothing you have done but it may have shorted out the oven sensor or the keypad. Check the sensor and see if it's closed. If it's okay, replace the keypad.
SOURCE: no model number anywhere on the range
Reach behind the upper-left corner of the control panel. There should be a 1"x8" aluminum flag that can swing up. The model, etc. is on there.
SOURCE: Maytag Stuck on "Delay"
You are in the Tiller and Cultivator section of FIXYA but have you tried unplugging or shutting off the Breaker for a few seconds and let the Oven 'reboot'? Ahh, what ever happened to the simple good old fashioned Ovens?
