Engine cuts out when engaging clutch or engaging blades..
Still need a fix it for craftsman 42" 15 hp kohler engine mower..starts fine .when releasing clutch OR engaging blades the engine cuts out..belts are on,bldes turn by hand. len
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
The transmission drive belt is a separate one from the blade belt. The clutch pedal when released puts tension on the transmission drive belt so it tightens up and drives the gearbox pulley by way of a large spring. Make sure the spring is ok. The belts don't last forever and probably needs replacing looking at the age of the machine. That is a fun job as it is right up under the machine and runs from the engine pulley right back to the top of the transmission. You have to drop the deck right off and I usually find a tree with a large branch and haul the front up with a rope or winch so the mower is vertical. Makes it easier to work on. Drain petrol first though. Hope this helps otherwise get a mower shop to do it for you if you feel it's to much of a task. Good luck.
You need to unplug the 6 PRONGED CONNECTOR down by the foot rest plate on the right hand side. When you remove it, you may notice that 2 prongs are missing. That is because there is only supposed to be 4 connectors, so don't worry and think 2 connectors broke off. Just leave that disconnected and the brake/clutch will be disengaged from the engine to allow it to continue running AFTER YOU RELEASE THE BRAKE! :) Which is what you had a problem with, just like alot of us. I have a PT9000 series Craftsman with the 28 HP Kohler engine. I wish I could upload a pic, but you'll see it when you look at it. It is easy to get to, and you shouldn't need any tools unless it is seized on REAL good!. After I disconnected it, I started it, took off the brake, fired up the snow thrower attachment and was able to move it forwards and backwards.... Another issue that these are prone to is being able to run the engine, but the mower will not move forward or backwards (And YES it is NOT in Neutral! :-P) maybe another connector issue... LOL Soon nothing will be left connected except the starter switch at this rate!.. Anyways, Theres your fix!
You should be able to push it forwards as well as backwards. I had a similar problem (engine stalling) with mine. I found out if I half choke it, it will stay running. Transmission may still have a problem.
The PTO switch contacts to operate the clutch that starts the blades is defective. I have replaced mine and the new one just failed again. Sears must know this is a defect problem but so far they are quiet about the problem
I would check the wires and clean the connectors and make sure seat switch is working. If that is not working, it's like getting off the seat without holding the brake/clutch pedal down or getting off seat with blades engaged. Both will cause engine to die.
It may think you are in reverse and is killing the motor to keep you from backing up with the blade running. Look for switch that is telling it when you are in reverse, maybe it is stuck with grass or other debris. another possibility is that the blades are jammed and they are stalliing the motor. Mines stalls easily when cold.
