Kenmore 53642 / 53644 Side by Side Refrigerator Logo
Posted on Oct 23, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ice Maker not getting water Kenmore Side/Side 53642
Red light is solid, but no water to ice maker.
  • Badgirl07 Dec 22, 2007
    My ice maker does not make ice and water is appearing on the floor.
  • Anonymous Mar 14, 2014
    i need to hook up my ice-maker in my kenmore side by side modle number 25351624100
Anonymous
Level 2:
Scholar:
  • Expert 146 Answers
  • Posted on Dec 26, 2007
Anonymous
Expert
Level 2:
Scholar:
Answers
146
Questions
0
Helped
77990
Points
279
2 things that could be wrong with these ice makers (Red light is solid, but no water to ice maker and My ice maker does not make ice and water is appearing on the floor). Either you have a defective water valve or your incoming tube is iced up. 2 ways to check:
1. Check your ice maker valve which is at the bottom of the refer. To find follow the water line into the back of the refer. it should connect to the water valve. Check and make sure there is 125V to the valve when it is in fill mode. Or look for and open condition at the solenoid (you check for open with a meter). When checking across the leads you shouldn't get any meter movement at all.
2. Remove the ice maker or the port that comes into the ice maker on the back of the refer (it is usually held in with 2 screws). Make sure it is not frozen up. If it is sometimes if you take regular insulation and pack it into the area where the port comes in that can stop the freezing problem.
Good Luck!
God Bless
Ice maker not making ice. red light on control panel blinking twice.
Remove the ice bucket and inspect the ice maker for an ice cube stuck in the ejector. Hit it with a little heat of a hair dryer till it gets loose and the ice maker starts rotating. Replace the ice bucket. See if it starts making ice again amigo.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
2helpful
Sounds likw the water fill tubs is frozen shut, look where the tube comes into the freezer compartment and take a hair drier and thaw it out. Good Luck
1helpful
ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Water Freeze to Ice maker
Usually when this occurs it is due to a leaking inlet valve. Replace that and you'll be in good shape.
1helpful
Ice maker
I am having the same problem with mine.
2answers
Ice maker
poss a problem with a blocked filter?
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
