Question about Toshiba Satellite A205-S4617 Notebook
Touch pad not working light bar not on above the touch pad
  • Cheryll Washington Jan 21, 2014
    M305d-s4829 is the correct model nmber
    New Friend:
  • 25 Answers
Hi Cheryll,
Make sure there are no problems with the driver installed on your machine by going to Control Panel->Device Manager and see if there are any question\exclamation marks on one of the drivers. While you are at the device manager you can check the touch pad driver version and update it to the latest from the manufacturer website if needed. To check the driver version double click the touch pad and go to the Driver tab. You will see it under driver version.
Also some netbooks got an hardware button to shutdown the Touch Pad.
Regards,
TheSmacker.
Posted on Jan 21, 2014
Anonymous
SOURCE:
The water stopped coming out of the water dispenser and the ice maker will not make and drop ice. The line from the house to the fridge is not clogged, the lines to the icemaker do not appear clogged.
Sounds like someone accidentally locked you out. If you see a RED light lit above the touch pad.
To Lock Out Press the LOCK Touch Pad for 3-5 seconds. A Red light will appear above
the Touch Pad.
To Unlock
Press the LOCK Touch Pad for 3-5 seconds until the Red light above the
Touch Pad goes out.
Other possibilities:
Household water line valve is not open. -open valve
Freezer door is not closed-Close door tight
Ice & water filter cartridge is clogged-replace filter
Front filter not fully installed, if equipped-Push filter until you hear a CLICK. filter should be FLUSH with cabinet
Here is a link to the user manual.
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/241572801en.pdf
Hope this helps
Thanks
Please rate FIXYA
May 26, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
HOW TO lock touch pad in my compaq cq62 laptop?
there is a light above your touch pad and a small button directly below the light. When it is white the touch pad is on. Turn it off and the light goes red.
Apr 02, 2011 | Compaq Presario CQ60-220US PC Laptop
HP Dv4 TouchPad buttons not working
hello
try to check the button above the your touch pad there is a locked and unlocked button, red light is locked, blue light is unlocked. and if your touch pad button is unlocked. if still not working try to check your o.s or third party software.
thanks
Mar 03, 2011 | Computers & Internet
My mouse pad scroll isn't working. I cannot move The mouse to click on any icons.
Toshiba usually has an on/off switch right above the touch pad. If there is a red light above the pad then it is turned off.
Dec 11, 2010 | Toshiba Computers & Internet
My Acer Notebook Touchpad won't work. How can I fix It?
Does it have a bar above the touch pad? Some have this to turn off the touch pad, HP's are famous for it. If not go to control panel and check the mouse feature to make sure it is installed. You can also go to system and look under hardware to make sure it is installed and working. Any yellow exclamation points are a sure problem.
May 22, 2010 | Acer Aspire One PC Notebook
My HP Mini touch pad is locked up. There's a red light right above the touch pad that is usually white.
on the new hp mini - you double tap the touchpad indicator (upper left) to toggle the touchpad on & off
Oct 30, 2009 | HP 2133 Mini-Note Notebook
Touch pad
Chek the color of the light attached above the Touch-pad.
That must be Yellow.
Click the button just by the side of the touch-Pad.
It will be green. You should be able to use the Touch-pad then.
May 12, 2008 | Microsoft Windows Vista Ultimate Edition
Enabling computer mouse
did u hit fn key or botten above mouse turn the mouse on ??> buy usb one mini
Jan 16, 2008 | Toshiba Qosmio G25-AV513 Notebook
Toshiba Satellite A205-S4617 Notebook Logo
55 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
