Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis Washer Detergent slot codes; what do they mean?
We purchased a stackable Bosch Axxis washer and dryer and the installers did not leave an instruction manual for the washer.
Where does one load the detergent?
When I open the drawer at the top left of the washer, there are 3 slots approximatley denoted as "II", "*", and "I". What is each slot for?
Thanks,
Tom
Soap goes in far left
softner middle
liquid all fabric bleach or powder bleach in far right
Posted on Jun 24, 2009
  • coco43
    coco43 Jan 23, 2012
    Doesn't the soap go in receptacle labeled "I" ??? If yes, then that receptacle is on the far right in my Bosch Axxis.
  • 864 Answers
Here is the manual: http://www.bshextranet.com/files/techtoolbox/WFL2060uc-ii.pdf
The answer to your question is on page 7.
Posted on May 31, 2009
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 79 Answers
You can fetch a PDF copy here - Bosch Axxis Washer Manual
Posted on Feb 28, 2013
    New Friend:
    Greenhorn:
  • 56 Answers
Did you check the manual section? Try it, it will help :)
Posted on Nov 16, 2013
6ya staff
SOURCE:
How do you unstack a Bosch Axxis WTA dryer from a Bosch Axxis WFL 2050 washer?
You do not state the type of stacking kit installed on your Bosch washer. The installation instructions of one of the stacking kits is found at the site Assemby Instructions Bosch Axxis Stacking Kit /WTZ11310.pdf . First remove the front concealment strip to expose the front of the mounting kit. Gently pry with a wooden tool to prevent damage. Once the it is exposed, there are two clip inserts in front of the dryer feet that must be removed. Once these are removed, you pull or slide the dryer forward to release them from the stacking kit and simply lift the dryer off of the stacking kit and the washer. The stacking kit itself is attached to the washing machine with four screws that must be removed to separate the kit from the washer top. And with that, your dryer and washer are separated!
But after separation there are two additional problems that may be bothersome to you. The first is that you now have mounting holes in the top of the washer that are exposed and the second is that the feet on your dryer may need to be replaced as parts of the feet may have been tossed during installation of the stacking kit and may need to be replaced.
The assembly instructions above show only the basic stacking kit. Some kits included a slide that pulls out to allow for a handy tray but the installation or disassembly is nearly the same.
Sep 13, 2014 | Bosch Axxis WTA 3510 Electric Dryer
Need instructions to stack Bosch Axxis washer & dryer - 24"
You can find the manuals at this link
http://www.bosch-home.co.uk/customer-service/download-instruction-manuals.html
Dec 22, 2012 | Bosch Axxis WFL 2060 Front Load Washer
Bosch AXXIS WTL 86300 condensation dryer leaking water
It's a classical error code, you can find all the error codes together with the troubleshooter within the manual under this article:
Nov 29, 2012 | Bosch Dryers
I just got a Bosch WAS20160UC AXXIS front load washer with BOSCH WTV76100US AXXIS dryer. the washer and dryer slide across the floor. I then put a rubber mat under it but it did the same thing. What is...
Welcome to FixYa.
i'll start with the most obvious, but still quite common oversight, have you remove the shipping bolts from the rear of the washer ?
i.e.
The next thing to pay close attention to is detergent usage. Regardless of what one may have been told, "He" detergent has to be used, and even then not too much.
Look for this symbol when buying/using detergents...
These are the most common things that can (and DO ) contribute to the machine acting in the manner you've described.
If neither of these things apply to your situation, please let me know and I'll be glad to assist you further.
Thank you for choosing FixYa and Good luck.
Regards,
Macmarkus :)
Oct 07, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Can you stack if they weren't designed for it?
ive seen people build there own stack unit. alot of techs will tell you no but ive seen this done and there has been no issue. just make sure your platform is strong enough to handle the tumble of the dryer during normal operation
Jun 24, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Bosch axxis washing machine detergent symbols
There are usually 3 compartments in the drawer, the smallest is for using fabric conditioner, the largest is where you put the powder or detergent in, the middle size one you do not put anything in, as it is where the cold water comes in for rinsing.
Plz rate my solution.
Thanks.
Jan 26, 2009 | Bosch Logixx WFT 2806 Front Load...
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Neptune stackable washer...
You put the detergent directly on top of the clothes.
Jul 31, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Bosch Axxis WFL 2060 Front Load Washer Logo
23,336 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
