Question about Pride New Mobility Legend 4 Wheel Scooter
Pride victory battery led lights flashing red and green
5 Suggested Answers
oregoon
  • 175 Answers
SOURCE: THE SCOOTER MAKES A HIGH PITCH NOISE WHEN THE KEY IS TURNED ON
The buzzer is a piezo-electric device that is the "horn" for the scooter. It also will alert when the scooter is in reverse, if this option is programmed into the scooter. It receives its power from the PC board or console board which is located inside the top of the shroud at the tiller, where the thumb paddles that direct the scooter are located. If liquids have reached the board, or if condensation has affected the board, the circuit that controls the buzzer may have shorted causing it to come on constantly.
Opening the top of the shroud is fairly simple. Remove about 6 screws holding the clamshell cover together, remove the speed adjust knob, and it should come apart. Inside you'll see a PC (printed circuit) board, green in color with lots of small electronic parts embedded on it. The buzzer is also inside, usually about the size of a marshmallow and black in color with tiny holes to let the noise escape. There will be two wires leading from the buzzer to the plug-in at the PC board. Unplug the buzzer and the noise will stop, but you won't have use of the "horn" at all. Replacing the PC board can be done by a certified Pride tech, but it will probably cost you about $150.00 for parts and labor.
Hope this helps.
Posted on Jul 07, 2009
oregoon
  • 175 Answers
SOURCE: I have a pride victory xl8. Problem - was running
All scooters have a protection system built in to prevent burning up the motor, and the user, should the scooter overheat. It sounds like yours overheated. If the temp. outside was warm to hot, and your weight is near the weight limit for the scooter, and you are taxing the motors over a hill, or unstable terrain, then the scooter goes into "limp home mode", or just enough to get you a bit aways, and then it will turn off. After a few minutes to cool off, it will go again, but shut down fairly quickly because it takes a spell to let the whole transaxle-motor assembly to get cool.
Check your weight, and anything else you may be carrying with you on the scooter. Check the terrain, and incline you are going against. Throttle down for all these occassions. If you overloaded the system at some point, then you may have overheated the brushes. Remove them (2) with a standard screwdriver and see if the copper coil is still flexible and springy. If not, replace it/them.
The damage may already be done, so it may need a new motor/transaxle assembly. An expensive proposition I'm afraid.
Posted on Jul 09, 2009
Will
  • 25 Answers
SOURCE: I own a pride victory scooter that stopped
possible blown fuse or breaker needs to be reset.
Posted on Sep 15, 2009
littleone121
  • 23 Answers
SOURCE: i have a old pride victory 3 scooter working well
It is best to let it charge at least over night, longer if it hasn't been used for a while. It is also good to give them a long workout (Don't completely flatten them though) at least occaisionally. If they get regular and thorough use they will last longer, but extra weight like shopping, or lots of steepish paths will flatten them a lot faster. They are only supposed to last a couple of years, but will go longer if you look after them.
One of the most important things is to find a supplier/repairman you can trust. These are, after all your legs or mode of transport you are talking about.
Posted on May 06, 2010
Kelly Hickman
  • 79 Answers
SOURCE: battery charger for pride
Is there a power switch on the charger? Is charger connected to the battery? Are the batteries fully charged?
Posted on Aug 20, 2011
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Oct 05, 2017 | Pride Health & Beauty
Victory pride 2002 won't work?
hi Wendy it sounds like the batteries are so low that they can't even power the horn ?
check the batteries connection and the reset fuse situated at the rear .
regards
Rob
www.gewizrepairs.co.uk
Feb 18, 2017 | Pride Health & Beauty
Why does green light on charger stay on?
Most pride chargers show up the green light when batteries r charged...when charging u should have a red power led & an orange led ...hope this helps
Jan 07, 2016 | Pride Mobility Products Go-Go Elite...
His I've a victory xl mobility scooter and constantly red flashing on battery meter and don't charge battery's properly can u help cheers
Hi, at a guess I would say that your batteries possibly no longer hold a charge. If the scooter has been provided for you get the organisation who gave it to you to check it over, they should service it for you.
There is a link below for the website that provides an owners manual, this may help you troubleshoot the problem
If you need anything else please post another query.
Pride Mobility Victory XL 4 Owner Manual
http://www.manualslib.com/manual/718600/Pride-Mobility-Victory-Xl-4.html
Jul 16, 2015 | Health & Beauty
Pride Jazzy 1103 Ultra controller code: when the "on" button is pushed and held down, three red, four amber, and one green LED come on and are solid (not flashing), and there is a second LED gauge...
Seven blinking LED's indicate a "Joystick Fault" on the controllers Pride uses. Could be just the actual joystick itself, the part you move to make the chair move, or it could be other electronics in the controller. Here's a link to troubleshooting info:
Pride Mobility Products Corp Basic Troubleshooting Instructions
Dec 21, 2014 | Pride Health & Beauty
Lights work no power
Check you're freewheel lever if its in freewheel u have to take the key out engage lever & put key back in. Also if u have left the key on for more than twenty minutes the circuit will shut down only the light will work. take key out for 5 minutes then put it back it should work unless it's another problem good luck
Apr 19, 2014 | Pride Mobility Products Health & Beauty
Ed light flashing
I think you might try the reset switch on the battery pack
Apr 24, 2013 | Pride Mobility Victory 3 Wheel Electric...
My victory 4 mobilty wont charge the green light is very faint/the charger was tested working.so why wont my scooter charge
make sure battery cables are secure at battery terminals and clean.how old are the batteries.If the batteries run down fast they are no good.a good way to test them is put scooter against some thing solid and go forward.If the battery indicator drops to o the batteries are no good.It takes about 10 hours to charge the batteries
Mar 15, 2013 | Pride New Mobility Victory XL 4 Wheel...
We put new batteries in it. We had them tested so
Hi. Have you checked the free-wheel lever is in the correct position?
Is one of the battery lights or any LED flashing? If so, count the flashes between the pauses, and let us know.
E mail at scooterworks@xnet.co.nz
Good luck. Neil.
Jul 23, 2010 | Pride New Mobility Victory XL 4 Wheel...
Pride New Mobility Legend 4 Wheel Scooter Logo
19 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
