Not cooling properly. Wine cooler
SOURCE: 15WC wine captain. Unit
temp control is the only answer sorry the unit turns on with it and off with it .
hope this helps
SOURCE: Wine cooler #ULN-75BWC-00 motor seems to have shut
the motor could be defective or it could be low o refrigerant causing the pressure switch to not kick on the fan. Could even be wires have come loose from the fan. If the fan does not work it won't cool. however it mould most likely cosy you more to fix if you take it to a shop to have it repaired if you have the tools to test it with I can help you so let me know if you have a test meter volt ohm meter and I can tell you how to test the system.
