Question about Kenmore HE2 Plus Front Load Washer
Water leaking from front - Kenmore HE2 Plus Front Load Washer
    Top Expert:
  • Kenmore Master
  • 14,162 Answers
Posted on Jun 16, 2015
Where is the hot water heater located on a 2012 keystone Montana high country and what are some caused of leaks under the furnace return
possible tank leak in back where supply lines go in or bypass leaking check under front compartment in front of heater
Dec 01, 2017 | Water Water Heaters
Washer leaks
There is also a discharge lint filter on the front lower left that has to seal properly. If the water appears only when washing, you can probably eliminate leaking from the water supply side up to the solenoids controlling the water. The most likely source is a leak in the rubber section between the tub and the front door, a leak in the seal between the door and the washer, a leak or overflow in the soap dispenser, or a leak in the discharge side components. You could probably figure out the source if you could view these areas during a cycle, but that would require some disassembly of the cabinet so that you would need to know what you were doing.
Jul 13, 2014 | LG WM2101H Front Load Washer
I have an LG front loader washing maching, model# WM2277H* I have changed both the hot/cold water value and the washer is still leaking.
if leaking on front unit : check rubber seal front glass door. if it ripped you should change it.
If leaking behind unit : check water hose , is it placed properly ?
If leaking under unit : call technician to repair it.
good luck.
Mar 25, 2011 | LG WM-2277HW Front Load Washer
Headlight washer system leaks out all the fluid just sitting without using the pump button
first check where it's leaking from, if water dropping near front wheel it's leaking from tank first check the rubber grommet for both washer motor 1 wiper washer motor and 2 head light washer motor, both are in the water tank, if your car water dropping from front end under the front bumper it should leaking from washer nozzle in this case need to replace the head light washer nozzle. some time leaking from hose if you check from underneath you can see where it's leaking from,
Nov 20, 2010 | 2000 Mercedes-Benz S-Class
My 2006 charger 3.5 is leaking coolant but only somtimes is it a sign of water pump malfunction no indications on the gauges but car seems to be running hot
this is most likely the water pump if it is leaking at front of engine, the water pump is under the large timing belt cover and driven by the timing belt, so both are changed at the same time.
Feb 04, 2010 | 2006 Dodge Charger
Water leaking bottom front door
Check out the front seal carefully for a replacement. Due to the flexibility of the seal, it is not to easy to spot a tear mark, Under pressure of an operation load, a small tear will allow water leaking through, so there is a leak. It is very common that a hard sharp object left inside clothing and during washing cycle, it makes its way to the seal and cause a damage. Hope this can help.
Jan 08, 2010 | LG WM2487H Front Load Washer
Frigidare front load washing macine leaks water
Sounds like the dispenser is leaking somehow, there is no filter that would cause it to leak. Remove lid of washer by screws on back lip and inspect during fill to see where leak is.
Jan 20, 2008 | Washing Machines
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
100 people viewed this question
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
James Hensley
James Hensley
