I somehow messed up by getting involved with those programs: Advanced System Cleaner, Iobit Registry Cleaner, and others. Now, my computer won't let me get into any of my games, You-Tube, and other apps that need Adobe Flash Player. This is what happens: Says I need to install Adobe Flash. According to my programs I already have it. After I install it I try to get into a game and the same thing happens again over and over. Then, at 1 time it said my rtl20bpl is missing and to reinstall. I also might add, I uninstalled all those system cleaner programs and this still happens. I am not computer literate but have learned quite a bit. , But: "I NEED HELP"!!! "PLEASE"!!!
On the browser is a gear on the right upper corner, click that and then click internet options, then click the advanced tab, then click on reset browser, it will ask if you want to do it, say yes, then restart the browser, when you try to access anything that needs flash player, it will tell you that you dont have it and it should offer a link to install it.
Hi download fanatic. I think you already download some called spyware, malware, or maybe virus.
try download this.
SUPERAntiSpyware Remove Malware Remove Spyware AntiMalware AntiSpyware...
Finish download, install it and update and run full scan.
after finish scan download online virus scanner called
HitmanPro 3 Second Opinion Malware Scanner
Full update and restart your system. Run your system to safe mode with networking ESET Knowledgebase or Start your computer in safe mode Microsoft Windows Help . When you get into safe mode with networking, please run Hitman again (hitman cannot run without internet connection).
After finish all scan and clean. Go to add and remove software and remove software you want to remove ( in safe mode). After finish remove, restart again into normal mode. Maybe this is the solution you need i can help.
thanks,
SOURCE: Cannot boot Gateway MX6421 after Unmountable Volume Error screen
If you happen to have your COA #, just go to http://www.microsoft.com and reload windows.
Let me know if theis helps.
Thanks for thr rating.
Mark
SOURCE: Notebook will not boot
If I understand what your problem is...
I had the same problem, it was a caused by bad Windows XP install CD.
Call Gateway and explain the situation, you may need to have a magnifying glass handy to read the tiny engraved lettering in the center of the CD disk.
Have your 'Product Key' available.
If you have some kind of sales receipt, or other "Proof of Purchase" have it handy too.
You will need to tell them, you do not have the program installed on other computers.
They can send you another disk.
This method will only work if you have a legal copy of the program.
SOURCE: BSOD
Apparently w22n51.sys is an Intel driver. It looks like this problem has been resolved by installing the latest Intel PRO/Wireless 2200BG drivers that you can find here...
http://downloadcenter.intel.com/Filter_Results.aspx?strOSs=All&strTypes=all&ProductID=1637&OSFullName=All%20Operating%20Systems&lang=eng
Another resolution I've seen posted in forums is to disable the Intel software or uninstalling it completely and allowing Windows to mange wireless connection.
Hope this helps!
SOURCE: I cannot open my computer because of my password.
When u powerup press F2 or "del" F1 key to enter in bios.
but if u have problem of bios password followbelow procedure
here are 2 password type first 1 is bios password if tell me about your bios password it prompt when u powerup follow procedure below
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Then it not want password.
And if u tell about windows password
Then when you power up the computer press F8 key then enter in safe mode then wait until it prompt for user password
then enter in administrator then if u able to enter then reset your password.
But if u set and forgot default administrator password then u should need winxp recovery disk.
