Side by side modle. fresh food at 51 F and freezer at 18. Preset at orig factory settings. Frost build up on lower freezer section back panel. Coils behind frig are dust free.
SOURCE: Frost buildup
It is not defrosting. You have to remove back wall of freezer where frost is and take hairdryer to melt away frost. You need to check defrost heater. This is on bottom of evaporator coils. It has wires going to it on both sides. This has to be checked for continuity. If ok on top of coils is a round unit called a defrost terminator. This needs to be checked for continuity also. This must be done before you defrost coils. It should have continuity when its cold.
If these are ok you probably have a bad timer or defrost board.
SOURCE: Kenmore refrigerator Freezer is cold but fresh food side is warm
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
The fridge gets its cold air from the freezer through a vent(damper)
between the freezer and fridge.The fan in the freezer blows air through it.
Make sure this fan is running. You may have to hold the door switch in for it
to run. There is a flap you adjust with
the fridge temp. control. Make sure it's opening and closing when you adjust
the fridge temp.
The problem could be the electronic control if
you have one or the mechanical linkages.
SOURCE: Freezer too cold, has frost on food and frig is
There should be separate temperature controls for each side correct?First,try turning the freezer side to a warmer temperature setting.Not just a little but a lot.It takes about 24 hours for it to adjust to the new temperature,but you can check on it every couple of hours.If nothing changes,it is most likely the thermocouple within the freezer half.It basically reads what temperatureyou want,reads what the current temperature is,and tells the refrigerator when to send more cold air.If there is a noticeable change,we will have to look elsewhere.A thermocouple is basically a metal rod with 2 leads coming out of it into the back of the refrigerator somewhere.It may also be small sometimes,or hidden under a plastic cover.Google thermocouple and it should show some pictures of it.They are for the most part the same with only slight variations in length or width.Greg
SOURCE: Kenmore refrigerator Model 253-68232800 will
Top of Form If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within. Please check the link below for tips to remove the panels/parts: http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Thank you for contacting fixya.com.
Check the coils on the rear of the refrigerator and make sure they are clean and dust free. Also check the back wall or floor of the freezer section for frost. Check the evaporator fan to see if it is running. Check the condenser coils under the unit for blockage from dust. Check the condenser fan under the unit to see if it is running. If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost terminator, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. Also check the freezer to ensure it isn't over loaded with food stuff, reason being air must flow freely threw out the entire refrigerator in order for the thermostat to work correctly.Defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with both the doors open to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
Hi, Thank you for contacting fixya.com. Check the coils on the rear of the refrigerator and make sure they are clean and dust free. Also check the back wall or floor of the freezer section for frost. Check the evaporator fan to see if it is running. Check the condenser coils under the unit for blockage from dust. Check the condenser fan under the unit to see if it is running. If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost terminator, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. Also check the freezer to ensure it isn't over loaded with food stuff, reason being air must flow freely threw out the entire refrigerator in order for the thermostat to work correctly. Defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with both the doors open to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
