Question about Amana Refrigerators
How many cu ft does amana model BX21VW have - Amana Refrigerators
5 Suggested Answers
Anonymous
SOURCE: Haier 1.7 CU Ft. Refrigerator - what is warranty
1 year parts and labor
Posted on Aug 17, 2008
rpbuice
Ron Buice
  • 161 Answers
SOURCE: Ice build up in freezer
Defrost system failure.
Defrost timer, heater, therma disk, any one could be bad.
You could manually defrost and this would get the Ref back to working for a couple of days before it iced up again. Remember there is a lot of ice build up on the cooling coils in the freezer that you can't see so, a little extra time with a hair dryer is needed to do a complete manual defrost.
Posted on Jan 21, 2009
SOURCE: How to replace the rear wheel on Amana 22.1 cu.ft refrigerator
Remove anything in the unit that could spill or tip over. Raise the front leveling legs to allow unit to roll. Slide the unit out from the wall. Place something between the refrigerator and the wall to protect surfaces. ***Make sure you have someone to assist with this next part. Tilt unit to the side and lean it against the wall to raise up the roller to be replaced. There is a metal base that supports the rollers, compressor, condenser and fan motor. You will see a heavy duty metal pin that goes through the roller. Bend down the metal tab in the base to remove roller pin. Replace the roller, reinstall bin and bend the tab back up. Carefully set the refrigerator back down on all four rollers. push back in place and screw down the front leveling legs.
Posted on May 02, 2009
rockitman187
Randy Hough
  • 2559 Answers
SOURCE: freezer works but frig is not cold
That could be it.
Posted on Jul 16, 2009
Anonymous
SOURCE: looking for cu. ft. info on fridge - hotpoint
It's in the model number.
ctx14<---- 14 cu ft.
Posted on Feb 16, 2010
How many cu. Ft. Is the Amana TR21VW?
The 21 in the model should be the cu. ft size.
Apr 02, 2015 | Amana Refrigerators
What is the cu. ft. of this model refrigerator Amana TZ21Q2L
Per my Manual , The Amana TZ21Q2 is 21.1 cu ft. and energy guide $69
Apr 02, 2011 | Refrigerators
My new amana model #a2rxnmfws01 freezxer is not staying cold and the ice maker is not working
your amana freezer internal defrosting heater is not working, have the electronic board check for problem..
Feb 09, 2011 | Amana A2RXNMFWS (220 cu ft) Top Freezer...
What is the cu ft of this fridge
the tell the cu size ck the model # as its in the # like a amana model arb 23tbs / this would be a 23 cu ft unit hope this will help . mm
Jan 20, 2011 | Refrigerators
MAYTAG FREEZER CAPACITY
I cannot find a MQU8057AEW in the Maytag library. I did find a MQU2056AEW that is 20 cu ft.
May 05, 2010 | Maytag 20 cu. ft. Upright Freezer MQU2056B
Filter change
didnt post the model number, but a general rule of thumb is the filter is in top right section of refrig compartment, a counter-clockwise turn will unscrew and rescrew the new one in
Nov 10, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
350 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
