Toshiba Satellite 1905-S301 Notebook Logo
Anonymous Posted on Oct 22, 2007
I have upgraded the one (1) user serviceable memory slot on my laptop.  I have no idea where the second slot (to be installed by Toshiba Service Center) to upgrade that memory also. Thank you
  • Anonymous Oct 23, 2007
    Thank you very much Great work
  • Anonymous Nov 15, 2007
    Thanks for your help I have looked for this forever. Any speed up tricks you can share. I have IE7 and it takes 100% of my 2g processor to open. I have all the add-ons shut down that are not required, disk cleaned and defraged, no virus or trogans, up to 1meg of memory it just is slow and sometomes stops responding when I open IE7
    Thanks
Anonymous
Level 2:
Scholar:
  • Expert 84 Answers
  • Posted on Oct 23, 2007
Anonymous
Expert
Level 2:
Scholar:
Answers
84
Questions
0
Helped
47022
Points
167
  • Anonymous Nov 16, 2007
    What operating system are you using?
    Which Anti virus and spyware programs are you using ?
    Are you using addtional firewalls other than windows ?
    Now if you go to task manager, by hitting , control, alt, and delete at the same time, then click on processes. You will see the programs that are using high cpu & memory usage.
How do you access the partition menu on a toshiba satellite 1905 s301 so i can delete it and intall a new os?
You just boot from the install cd/dvd, you get the option to delete partitions as you go along.
1helpful
Where can i purchase a MPC13A-20/R 802.11b card for my Toshiba Satellite 1905-S301?
This is the only card that works in the mini-PCI slot in the 1905 series. eBay would be your best bet. You can look under "Toshiba 1905 wireless card" but ... make sure it's an Agere card, as most sellers are selling Intel, Broadcom, Atheros.... and none of them will work.
Toshiba Satellite 1905-S301 , will it run on a/c power with the battery out?? Not showing that it's charging when plugged in.
Yes it will run without battery in place... it not you may have charger plug or lead problem... let me know...
1helpful
I purchased 512MB PC2700 333 Mhz memory module on ebay.... put it in my toshiba satellite 1905-S301 , would not work right removed module and nopw it will not power on, and when i push power button with...
remove the ram and battery try to power on. also you can power off add install ram without battery if power up .
if battery light is amber and blink speed. pls check the battery .if not battery charge pls check the battery and charge circuit
Toshiba Satellite 1905-S301 PC Notebook will not
Hi! You may want to toggle the function button designated for turning the monitor on or off. Press FN button together with th efunction button that has a monitor image on it. some system uses F2 of F3 button to do this. (Example: press FN+F3 or FN+F2 button together once while computer is on to turn on system display)
3answers
I have a Toshiba Satellite 1905-S301 that has 512mb of DDR memory currently. I have a stick of 128 that I was going to throw in there to boost performance but when I opened the compartment the there was...
There are 2 types of memory, one for laptops and one for pc.
Your additional stick seems to be for pc from what your saying.
Additional thoughts:
I'm sure you can buy sticks for laptops at walmart or whereever you bought ur laptop. Just make sure it is the same speed type. Example: yours is 512mb ddr PC 5200, you will need to find PC5200, the 512mb and up you shouldnt have to worry about. So do your research before you upgrade or you will burn your laptop.
1helpful
Can't switch on a laptop
this may be too late for you, but I had the same problem with my old toshiba laptop. The support person I talked to had me take out the battery, leave the computer plugged in and push and hold the on button for 10 - or 15 seconds. She said it discharges something or other and to periodically run the computer without the battery. Sometimes my screen just goes blank on my new computer and this always fixes the problem.
Good luck.
Sherrie
How can i format the HDD for my Toshiba satellite 1905-S301?
try on manufacturer web site, format it with cd room on startup
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
