I had to lay the KA on its side during transport and it leaked oil
SOURCE: how do I add oil to my kitchenaid stand mixer?
if the oil is black or dark green this is the transmission grease. There is plenty in the case don't worry. You may have a cracked transmission case or a bad gassket. I think the most likely thing is a loose screw or two. Take the trim band off, 1 screw. Then take the 4 screws that hold the cover on. You can now lift the top and take a look for the sourse of the leak
SOURCE: oil leak from Kitchenaid ultra power mixer
Ah, I found the solution.
http://www.fixya.com/support/t125253-mixer_leaking_oil
SOURCE: Kitchenaid mixer leaking oil
Some of the oil has separated from the grease inside the transmission, the grease should be replaced. You don't need a total dismantle,. simply remove the top cover and the transmission housing. Remove as much old grease as you can, then replace it with grease from Kitchenaid Parts, or locate a Shell Oil distributor in your area, you want Shell Darina XL EP-2. The oil that came out of your unit probably won't be enough to do immediate damage, but because it's separating, it's becoming less effective. It'a messy job to remove it but will add years of life to your mixer. If you find this solution helpful, please rate it. Good luck. ricardok45
SOURCE: Kitchenaid stand mixer oil leak
Hi. The grease that your mixers are lubricated with has reached a stage where the oil is leaching away from the grease. All your machines need this grease changed. Shell Darina EP-2 or Chevron FM ALC EP-2. These machines need to be internally cleaned and re-greased. It's important to remove the oil from any place that it drips. The planetary gear must be removed, cleaned and re-greased also. It's a messy job, but you can do it yourself if you're familiar enough with machinery. If not, then a suitable service outlet can easily do it.
If you choose to do it, go to the Kitchenaid website and locate the parts files for your particular model, these drawings will assist greatly with the project. If you can, take digital photos at every step of dis-assembly as a reference for re-assembly. If this solution assists you, please rate it. Good luck! ricardok45
SOURCE: Kitchenaid Mixer leaking oil
Hi Tim. Don't try to pour anything into the side openings, these openings are for the electrical brushes. You didn't state what model you have so my help is limited. Goto www.kitchenaid.com and click on the customer care tab. Enter your mixer's model# into the search window. Look for a parts catalog for your mixer. If there is one, download it.
Your mixer uses grease to lubricate it. If it's leaking oil, the oil and old grease must be removed and replaced. Chevron FM ALC EP-2 is a "Food Grade" grease, use it to replace the old stuff. The transmission housing and Planetary assembly will have to be removed to accomplish this. It's a messy, but necessary task. Once completed, run the mixer for a few minutes each week to keep the oil suspended in the grease, this will extend the life of the new lube. Good luck!
If this solution has assisted you please rate it. ricardok45.
