After cycle the washer will not drain. if you select drain the machine makes a whining noise
The possible reasons and solutions for this..
1)Drain hose is kinked or house drain is restricted.
Straighten the drain hose to improve water flow to the drain.
2)Standpipe is too high.
Standpipe must not exceed 96 inches in height.
3)Drain hose has been taped (or sealed) into the standpipe.
Tape holding the hose in the standpipe should
not form a complete seal. The standpipe needs air for proper draining.
Remove some of the tape to make an air path.
4)Drain hose fits too tightly in the standpipe.
There must be an air gap between the drain
hose and the standpipe for proper draining. The standpipe needs to be
at least 1 1/4 inches in diameter.
5)Also If too much of soap is used the washing machine drains slowly or will not drain at all..
thanks for feedback. based on another posting I read earlier i decided to take another look behind the pump cap with a flashlight...i found a paper clip jamming the impeller...i removed it and everything seems to working ok for now.
Washer machine doesn't fully drain, I can hear it drain but not completley
