Idont know how t separate the plasticdrum
SOURCE: indesit wash machine drum bearing
Some models like the WE12 have sealed drums where the bearings can't be changed. You have to buy a complete unit for about £120.
SOURCE: Bearings getting noisy
no need to remove the drum
u just unscrew the screws and spyder wil come and u can change the baring
SOURCE: My Indesit WIXL143 washer has
Sorry, I do not know your particular machine but before considering the ball valve, if it hasn't been done already, I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
SOURCE: how difficult is it to
Personally, my view is that this
is NOT a job for the uninitiated DIY enthusiast as it will mean stripping the machine
and removing the drum from the chassis, splitting it, removing pressed in
bearings and then sourcing and re-fitting new bearings. To
be frank, the cost of a bearing set (if they are replaceable, and most are)
will be about £20 ($30) or so. But it's a long and horrible job if you haven't
done it before. I know professionals who claim they can do a bearing change in
under an hour, I've done a quite a few and it takes me about 2 hours by the time I've
ripped the machine apart and reassembled it after the bearing swap. A local
repairer will probably attend and swap out your defective drum for a
refurbished one and then take yours away so he can refurbish it and put it back
in his stock. Sadly, this will take the price up to the point where you need to
question if the expense is worth it or do you get a new machine instead. I'm not saying that you couldn't do it if you had the will and the practical temprement, but I would certainly approach the idea of starting the job with a degree of scepticism.
SOURCE: Hi i have an Indesit
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
