LG WM3987HW Front Load Washer / Dryer Logo
A
Anonymous Posted on Jan 17, 2014
How to check if House fuse is blown - LG WM3987HW Front Load Washer / Dryer
Wont heat up
Good Morning Johnnie, thank you for your post!
Often when a dryer no longer heats, it is because either a fuse from the fuse box is blown or the switches on the breaker tripped, depending on your house. If your house uses fuses, there are two house fuses that supply voltage to the dryer circuit in your fuse box. If one of the two fuses is blown, the unit may turn but will not heat. Check and replace fuse in fuse box if necessary. However, if the house has circuit breakers, there may be two breakers with switches that supply voltage to the dryer and one also may have tripped. Typically, the heater of a dryer requires 220 to 240 volts to operate. If none of the tips above solve the issue, then it could potentially mean a number of other things: defective cord, a wiring failure, faulty heating element, or control board. Which in the case, I would personally contact a professional to accurately diagnose the dryer to determine the root cause to reduce the risk of unnecessary parts.
WHERE IS THE HOUSE FUSES LOCATED?
If you're reading your manual and it refers to "house fuses" they are the fuses or most likely now circuit breaker in your "house" that supplys the voltage to the dryer. In other words, check your main electric panel for a tripped breaker or blown fuse.
Dryer wont heat blows cold air
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
HE3t Kenmore dryer runs fine but suddenly stopped producing heat
No heat gas kenmore gas dryer
Dryer does not heat
Heating element
Thermal fuse
Wiring
Aug 07, 2009 • Dryers
1helpful
I checked everything now i am down to the timer will this cause the dryer not ti heat?
Heating element
Thermal fuse
Wiring
Dryer will not heat up
Heating element
Thermal fuse
Wiring
Aug 05, 2009 • Dryers
2helpful
Not heating
Heating element
Thermal fuse
Wiring
May 20, 2009 • Dryers
Gas dryer is not heating
Heating element
Thermal fuse
Wiring
Thanks Repairclinic
Aug 25, 2008 • Dryers
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
