Volcom Snowboard Pants Base Pant - sky Logo
A
Anonymous Posted on Jan 16, 2014
Volcom base snowboard pants
Do you this product: volcom snowboard pants base - sky size L?
Dalbello ski boot replacement parts
need heel replacement for Dalbello krypton cross ski boot
1helpful
How do I choose the size of the snowboard?
There are 2 factors for snowboard's size: Height and width. Height is measured for beginners from toes up to collarbone or chin and professionals prefer longer snowboards measuring between the chin and the nose.
The correct width for you is if you stand on the snowboard, your feet should stretch almost entirely across the board. You can use this cool calculator to measure the size you need: http://www.frostyrider.com/tips/size-guide.htm
What fit is this type of snowboard pants?
Call me crazy but most Snowboard pants as of yet don't have a separate "fit". That means you won't have any described as"loose", "baggy" "straight leg" etc. What you have instead is that snowboarding pants are made w/ space and flex @ the knees and are wide enough for boots @ the ends. Any adjustment to "fit would have to made in choosing what size you planned on wearing. Hence if you wanted em "baggy" get em bigger etc...
Broken zipper
I would go to www.volcom.com and find your local store and see if they will warranty the item or give you information as to who to contact at Volcom to repair the item.
Snowboard boots with reduced length
You may also want to look at how you are setting up your bindings. I have a US 11 foot (29 cm) and with my bindings set correctly have never had any issues with toe or heal drag.
The best way to set up your bindings it to take them off, remove the mounting screws, keep the base plates in and fit your boots into your bindings with the straps still undone. Then, with the board on the floor, position the binding at the angle you like (roughly) and look to see when the toe and heel over lap is even or if you are like me pull the bindings back slightly so that you have little or no toe drag and just little heel drag. It works a treat and I have done this for over a hundred customers over the years.
I am 5"2 and am 110 pounds and am a guy what snowboard size would fit me
prob a 142 board...but use this site - awesome calculator that will size a board for you just by putting in some info
hope this helps - good luck!
What does the number mean in the base measurement of snowboards?
It is the type of sintered base used on the board - the higher numbers indicate higher density and pressure used to make the base material - the better base will have more "pores" and will hold the wax better resulting in a faster board
1helpful
9helpful
4answers
Snowboard length fit
"Length is one of the most important characteristics of a Snowboard. The length of a Snowboard is measured from the tip of the nose to the end of the tail. The length is usually measured in centimeters and often abbreviated to just the last two digits. Board length varies from 100cm to 180cm. To find the appropriate length for you, start by comparing the board length to your height. Although there are no dead set Rules in Selecting Board Length, the following are several guidelines to get you started. When holding the board on its end: * Short board should reach somewhere between your collar bones and chin. Shorter boards are easier to maneuver, great to be trained on, and often preferred by riders who do a lot of Snowboarding Tricks, park and Pipe Riding. * Medium length should come up between your chin and eyebrows. This length is preferred by all around intermediate to advanced riders who ride a variety of terrain, including parks and steeps. * Long boards should go from your forehead to several inches over the top of your head. Long boards are used for high-speed carving, deep powder snow surface, and big mountain terrain. Choosing the suitable board length is not only influenced by your height but also by your weight. Keep in mind that a Snowboard acts like a leaf spring - it has no clue how tall the person standing on it is. However, it does know your weight. Based on your weight or body structure, the following will help you choose the Right Length of Snowboard: * Lighter people should have shorter, more flexible boards. This is because a lighter person on a longer board commonly has a hard time controlling the board and initiating turns. * For an averagely built person, the board length should reach somewhere between the chin and your nose. * Heavier people should have longer, less flexible boards. A short board isn't advisable for heavy riders because the board often have a tendency to ""wash out"" or perform poorly, especially at higher speeds. * Freestyle riding is often done with a shorter board to allow better maneuverability. * Freeriding, deep snow, and racing boards will be longer in size. * For riders who are into Backcountry Snowboarding, go longer for stability. You may also consider your aggressive or timid style. If you're the type of boarder who really attacks the hill, you'll want to increase the length of your Snowboard up to five centimeters from the average size. Then again, if your riding style is naturally slower in character, go down five centimeters. Still, keep in mind that one Snowboard doesn't do it all."
Top Volcom Equestrian Experts
Imagdrider
Level 1 Expert
john h
ADMIN Andrew
ADMIN Andrew
Are you a Volcom Equestrian Expert? Answer questions, earn points and help others
