It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If this is a timer controller type then the contacts or the function to move on is faulty and needs a replacement. The inlet valve works to allow water and then the motor is struck on and not moving to the next cycle. Test the controller to confirm, check with a similar type before you order for one.
