Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
Posted on May 29, 2009
B&D CMM1200 cordless electric mower starts but keeps shutting off.
Howdy, I have a Black & Decker MM850 electric mower that starts, then stops a short time later -- anywhere from few seconds to a couple of minutes later. It winds down slowly when it stops rather than cut out immediately. It does this 3 or 4 times, then after that it doesn't start. THis happened last week. Today I had a little time so I took apart the start lever assembly on the handle, didn't see anything unusual, so I cleaned the plug and reassembled. It did the same thing as before. I've had this mower several years, very reliable up to now. Thanks in advance for any help, Cliff I have the cordless electric mower- CMM1200 - and it started doing the same thing. It starts up fine, then after about 20 minutes, it begins to wind down and shuts off. It will start up again if I give it a rest for a minute or two, but I have a lot of land to mow and this drives me crazy. I just submitted this question to the Black and Decker website and will post the answer if I get one that's helpful, but I'm sure they'll just tell me to take it in to be fixed. Grrrrr! susan
  • Michael J Titera
    Michael J Titera Oct 13, 2014
    I have the same problem. Did you get a response from Black and Decker?
2answers
Black & Decker cordless lawn mower won't start
Hi Sandi-
This could be an issue with the battery itself or charger. The best way to know is to have the battery tested. You can follow the link to locate your nearest service center to have them tested.
Thanks
Black + Decker Customer Care Find Service Center
Short battery charge
The B & D MM575 mower is not battery operated nor is it cordless. CMM1200 CMM1936 CMM1836 are the currently available cordless mowers. You can buy a battery from B &D, they list it here:
http://blackanddecker.com/ProductGuide/Product-Details.aspx?ProductID=22989
tom
Instuctions to replace lawn mower deck
Hello
The only thing I can get you is a parts breakdown . If that helps here's the link
http://www.dewaltservicenet.com/SearchResults.aspx?q=cmm1200 and you just have to see the service tag to check the type you have .
Hope this help
Sep 02, 2009 • Garden
1helpful
2answers
B&D MM850 starts then stops a few seconds later, then won't start
I was having a similar problem. I tried starting it up with the switch case open. I saw a very tiny puff of smoke come out of the switch. I replaced the switch and it was fine.
2answers
Replacement batterys for cmm1200 black&decker electric mower I have a Stealth Black & Decker rechargable mower and would like to know what battery I need and can I replace it myself Thanks Cherie
I discuss the solution to your problem in my review. I am using a replacement AGM Lead Acid battery that increased my mowing distance and does not take more power to charge because the battery has an lower internal resistance. The battery is a Power Sonic, PSH-12180FR, 21Amp Hour unit. You will need to order two of them.
We should all do our part to save the enviroment and encourage the growth of the solar and wind power industries.
Cordless electric lawn mowers go a long ways towards these goals. I recently purchased the Black & Decker Cordless Electric Lawnmower the CMM1200.
In the review I describe how to upgrade the mower to mow over 9,000 SQFT!
I hope my review will help you make a decision about our future.
http://www.epinions.com/review/Black_Decker_19_In_24_Volt_Cordless_Mulching_Mower/content_445899312772
Sep 30, 2008 • Garden
I need the large cordless battery for the black and decker cordless mower, and also need the power charging board in the mower.
the largest is the 24v CMM1000. now the circuit board for the said model are hard to get. but upgrade are available & convert it to CMM1200 model. convertion kit includes instruction how to, a wiring assy & a charger.
2helpful
2answers
Black and decker cordless lawn mower CMM1200
cmm1200 switch in the handle problem. switch contact maybe burnt out. parts are available. see dewaltservicenet.com or toolpartsdirect.com for diagarm etc.
2answers
Black and decker cmm1200
call B&D 1-800 and ask for a manual
23helpful
4answers
You can find replacement batteries on amazon, click here and take a look: Amazon com Black and Decker 24 0 Volt Lawn Mower Battery 90508011. I hope this was helpful. Cheers
Black and Decker electric mower model MM850
maybe something shorted inside mower.
you need atleast 14 gauge wire
Top Black & Decker Garden Experts
Thomas Perkins
Thomas Perkins
Mike Cairns
Mike Cairns
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
