Welding Tools Logo
Andrey Shcherbinskiy Posted on Jan 15, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ya240a mig welder
I need circuit board schematics, on the model. I am trying to take it to repair service, and need to know numbers on transistors that blew up.
David Soto
Level 2:
  • Expert 414 Answers
  • Posted on Jan 20, 2014
David Soto
Expert
Level 2:
Answers
414
Questions
Helped
193771
Points
758
You can find all the century manuals and diagrams at this page:
http://www.lincolnelectric.com/en-us/support/pages/operator-manuals.aspx?q=wire+feed&type=text
Just click on it or copy and paste on your web browser.
5 Related Answers
Anonymous
  • 169 Answers
  • Posted on Dec 03, 2008
SOURCE: electrical problem with mig welder
Call Lincoln Electric (the manufacturer) at 216-481-8100 and ask them to email you one.
please rate my answer,
Carl
Anonymous
  • 92 Answers
  • Posted on Jan 23, 2009
SOURCE: need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
Anonymous
  • 4 Answers
  • Posted on Apr 08, 2009
SOURCE: WILL THE LINCOLN SP125 MIG WELDER WELD ALUMINUM AND STAINLESS?
The mig welder should be capable of welding aluminum not stainless but the makers should be able to give you more detail. mig is used for steel and aluminum normaly but I do not know this transformer
Anonymous
  • 18 Answers
  • Posted on Oct 26, 2009
SOURCE: mig welder schematic wanted for magnum auto mig
if you call the maker of the welder you can be sure the one they give you is right and its normaly free and faxed or mailed right to you.
Anonymous
  • 17 Answers
  • Posted on Apr 21, 2012
SOURCE: What do i use to power my linclon ln-25 suitcase mig welder?.
no it cannot be
1helpful
Main pcb 880-456-000 need schematic to troubleshoot.
Dana, Sorry no schematic, but I do remember the welders may of had bad circuit boards
I need Q1 transistor for 135 hobart welder
The transistor is mounted on the main circuit board, you cannot buy the part from Hobart or Miller, they only sell the complete circuit board.
If you can read any part numbers from the transistor you can purchase the part from a electronic parts supplier.
Wire feed problem with snap-on mig welder
There are two wires comming from the circuit board to the wire feed motor. You can try running the motor directly from a 12v battery or two for 24 volts. You might want to look at the name plate on the motor to check the normal DC current it draws. If you do not have an ammeter, you could use a fuse close to or just under the normal current. If it runs and draws too much current, then you know you have motor problems.
If it runs well and draws a fraction of normal current,you know the motor is good. Before you condem the circuit board, check that it is receiving the correct input voltage. If the welder is dual voltage,then somebodys mistake making voltage change could send 240 v to the board that is meant to receive 120v.
Hope this helps, Robert
Snap on ya240a 117-036 mig welder Problem
I have an issue with this same model, I need help, Got scammed on craisgslist and was sold ya240a with burned up circuit board. I really need help with pics of the transistors on it, and numbers on it. Since mine are blown. I cannot find circuit board schematics. I found someone who can salder the parts on for me.
I need a wiring diagrahm for a lincoln sa 200 can ya help?
I am a certified 6-g welder, and you can obtain the wiring prints through a welding supply company that sells lincoln products. Make sure you have the model number, as well as, the serial number. You will not find schematics posted online as this would be a rarely used post, so a dealer would be the fastest, and less time consuming effort.
The circuit board is bad on my 2175 solar welder,on the board is a number510-045-0. Where can I purchase a new board?
I find many links when I Google "solar 2175 welder parts", but don't know about NEW boards. You could get guaranteed repair of this 510-045-000 for about 84 dollars and 23 cents total. Otherwise (reading aloud & use all lower case)
Cee q Jay Jay u Nine Dash 838 At sbcglobal.net
will get you details.
Replace the off-board transistor cabled to the 3-pin connector (regardless of whether it is an MJ900 or MJ11015) at the same time with a new one in the repair kit. That's because a bad or missing off-board transistor can easily smoke a good board, specifically the surface-mount chip 723-type regulator on the solder side of the board.
Circuit board repair, century 117-042-905
I am sure there is one to download. If google is no help, just ask some deep web specialists, e.g. http://manualfox.com/schematic.htm - this is a schematic search agency and if they don´t find it, it does not exist in the Internet.
3helpful
3answers
Have a 110 volt mig wire feed. motor slows to a
To get parts for your welder you'll need to have the serial number off the tag on the case. This problem could have other causes, have you:
Checked the tension on the wire spool? You ought to be able to pull the wire by hand easily.
Checked the tension setting on the pinch rollers? Too much tension can drag down the motor speed.
You could also have a bad control card depending on which model wire feeder this is.
Regards,
Carl
2helpful
Need wiring schematic for miller 140 wire feed welder
Top Welding Tools Experts
ADMIN Andrew
ADMIN Andrew
littlewheel
Are you a Welding Tool Expert? Answer questions, earn points and help others
