Unable to open the battery compartment on my GE Mac1200 ECG
Is there a trick to access the battery. I have a replacement battery, but the plastic slide starts to open up a bit but does not slide free to access the battery.
Thanks for any help.
Hi, Its recommended that you should take the ECG on battery backup. Because if you use power line while taking the ECG there is a possibility of interference on the base line. Try to replace the battery before taking ECGs. OK
hi,
You have to replace the battrey of the ECG machine. Even if you are connected the power the machine works on battery. The mines power is used only for charging the battrey. If the battery is faulty then then machine will power off by it self. Its a 12v 1.2Ah battery. For replacing the you have to open the machine. You can't access the battery externally.
You can find the battery in the following link. http://www.foremostequipment.com/index.cgi?item=FME-26566&q=Spirometry&s=CATEGORY
hi, do the following for deleting items in memory. Press and hold down button and press store /retrieve button
u will see the memory program as follows
the first line reffers all the stored
else shows individual ecg in memory ( by name or by date) to delete all ecgs sect delete and press button if u want to delete one by one then select the ecg recording and press ok
They usually sell these by the pack but we have a lot in stock and I can separate them for you. I just need to know what style you have so that I can provide the right one. Send a pic if you can and I will help you with this issue.
[email protected] or 800-989-4909. www.overstockme.com
If the ecg waveforms are all over the place you are probally recieving electrical interferance. If that happens when nobody is connected try adjusting the filters and see if it makes a diffrence. If it does not make a diffrence it might be the patient cable or leads.
If you have further questions you can contact me at [email protected] or through our website www.overstockme.com
The battery is weak. Disconnect the AC, battery,& then replace the memory battery. Reconnect the power battery & AC. Next is a pain in the rear, reprogram the unit; date, ID, setup, ect.
I am not sure what you are referring to . Do you need just the connecter that is attached to the battery pack? I can provide almost anything for the mac1200. Please let me know.
[email protected].
www.overstockme.com.
Jeff Watson
