I have been doing laundry all day and my second to last load when i came down to switch it the door would not open when i tried to turn it on there was nothing, I checked the power cord unplug and plugged it back in and then checked the fuse box to make sure that was ok and it was, very confused
SOURCE: Maytag washer not reset after power outage
The magnetic switch was stuck due to power outage / contactor are spark connect the contactor stuck together .Magnetic switch to replace.
SOURCE: maytag mav7000aww washing machine doesn't work
My MAV7000AWW Maytag washer does not agitate, everything ealse works fine. It fills with water, spins & drains, anyone ant ideas
SOURCE: Maytag front loader washer--door won't open but lock light off
Open the soap dispenser. Look down in front of the fabric softener dish.
You should see a yellowy-green plastic cord (like weed-whacker line). Pull it.
The door should open.
If you don't see the cord, remove the four screws that hold the dispenser lid in place to find it. Just don't lose it when you put the cover back on.
SOURCE: i have a mah5500b. prob is washer will not start
I had a similar problem on my Neptune. All the machine would do is beep. I believed it was a stuck button so I got a new touch pad and that solved the problem. I also substituted a control board prior to buying the touch pad but the problem was the same.
