SOURCE: LG WFT1081TP Top load washer
The fuse is located in a black cover. You need to gently pull the front panel out of the way and look to the right of the unit, in the area under where the panel was. There, you will see a black wire running into a black cylindrical case that has a black wire running out of the other end. Heed the warning on the label, please, and make sure that the power is unplugged form the wall. Gently pry open the casing and you will see the fuse within. The ends of the wires just pull off (gently) and then you have the fuse.
Tomorrow I go on a fuse hunt and try this out.
SOURCE: Washer tripped breaker on elec. panel, reset, washer won't turn o
This sounds like something has shorted causing the breaker to trip. You definitely need a qualified LG repairman to check it out.
SOURCE: power button wont turn on or off not working but
I am having same problem- power button will not operate at all. If I open the door and manually spin the drum with my hand, the machine will power up, just as if I pushed the power button. It will then wash your load without problem, but I really would like to have the power button work. Only had it two years so far!
SOURCE: LG Washer (WM2277HB) won't turn on without unplug & plug in again
I'm having the same problem!!! ANY solutions out there?
