Stuck
The problem is: when last used, the contents of the container may have spilled over and seeped into the tab switches along the interior well of the unit. The tabs will not release the container as they are STUCK. Try a spry mist of window cleaner around the base of the container and let sit a short time. Try to move container around several times and see if it releases. It will not come out easy, and if forced, the entire unit will be damaged. Also, the hard rubber connector that engages under the container can become misaligned and when off center, it will bind up.
