Danby DWC283BLS Wine Cooler Logo
D
DRUS Posted on Jan 13, 2014
GASKET SEAL BAD
SEAL ON DOOR GONE BAD, NEED TO REPLACE WHO DO I ORDER IT?
hq120
Level 1:
New Friend:
Problem Solver:
  • Contributor 12 Answers
  • Posted on May 31, 2014
hq120
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
12
Questions
0
Helped
3991
Points
12
Try at sears parts direct
1helpful
Replaced freezer gaskets now not sealing well
Jay, Check to see if hinge can be adjusted so door closes tighter, may be a faulty door seal, or maybe it needs manipulated to soften, shape, stretch it to seal better. You can try the dollar bill trick between the seal and fridge to locate the problem/leaking spots. The bill should not pull out with out there being a little force, no force means seal is not proper in that area. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Check The Seal On Your Fridge And Oven
How To Test And Replace Bad Refrigerator Gasket
How to Fix Gaps in Refrigerator Door Gasket
How to Check Freezer Door Seal DoItYourself com
Hunting for door gasket/seal replacement.
get to a refrigeration and airconditioning parts supplies near you. they'll order the gasket for you. thanks.
Crosley side by side freezer and fridge have ice in bottom
Hello - A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Another possibility is an air leak and the cool air is causing the frost buildup. I suggest contacting a professional to move forward accurately and have them check the coolant system.
Pressure of the door is gone
The lower hinge on each door may have a door closing cam. It raises the door up Ā¼ inch when opening and this assist in closing the door. If it's wore out and doesn't work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Freezer door opens when we close the refrigerator door.
That usually indicates one of two things. (A) You door gasket has gone bad and needs to be replaced, or (B) the temperature in the freezer is not low enough to cause a good seal. You can check the temperature with a thermometer. It should be atleast below 10 F but preferably around zero F.
If you need further help, Iā€™m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
I have a 1989 honda accord dx with a oil pan gasket leak and a rear main seal leak, in order to fix the rear main seal leak, does the oil pan and the oil pan gasket need to be removed and does the gasket...
they don't use gaskets on oil sumps its sealant glue and yes u will have to reapply it when you put the sump back on, and what do u mean by main seal? do you mean the head gasket?
11helpful
2answers
Replacing LG Dishwasher door gasket/seal with Part # 3920DD3005A
Problem solved - it was not the gasket - it was the vent tube as defined in one of your on-line reported solutions. Thank you!!!
My whirlpool refrigerator is getting water buildup on shelves which is freezing. Why?
By not being there to check a few things it's a guess. It sounds like your dooe seal is not sealing, letting are in causing condesation. The air from the freezer is trying to cool it down causing the water to freeze. Take a dollar bill, holding it by one end. Open the fridge door and hold half the dollar bill inside so that the door will close on it. Now pull the bill out. If it comes out easy, the door is not sealing. Try this all around both doors. The seal should try to hold the bill tight. If you find that it pulls out easy from anywhere around the two door. Wet a hand towel with HOT water. Hold it over the place that doesnt hold the bill. You want to heat the gasket to make it soft. After you have warmed it with the hot towel, pull on the gasket only hard enough so that it expands. Now close the door and try the bill again. After you have gone all around both door doing this. Take Vasiline and rub a thin coat on all the gaskets. This should fix the problem. If you find that the gasket is torn. (They are bad about tearing around the bottom) Replace the gasket.
Please rate if helpful. Thanks
2helpful
2answers
Water in Floorboard tailgate area
Gasket on the door has gone bad and needs to be replaced. It seems like the door gasket is not sealing properly and allowing water into your vehicle or you have a leak in the bottom of the vehicle that needs repairing. But that is more then likely not the problem
Top Danby Furniture Experts
ZJ Limited
ZJ Limited
Are you a Danby Furniture Expert? Answer questions, earn points and help others
