Compaq Presario M2000 Notebook Logo
Posted on May 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Laptop screen fading in streaks
Hello! I've been using my Compaq Presario (M2223AP) Laptop for 2 years now, then all of a sudden I saw 2 vertical lines on the screen. 1 line is a clear red line (but not so thick & dark) located about 1/3 from the left of the screen while the other is a very faint (thin, almost transparent) line located about 1/5 from the right of the screen. I think it might be a monitor problem. I'm not very good in fixing computers so I have not done anything about it yet. I'd appreciate your help very much. Thanks! I have a Presario M2000 laptop. A few months ago we started seeing a fading of the screen. It started on one side, the color was faded in a 3-inch wide section from the top to bottom of the screen. Later, a larger streak appeared on the opposite side of the screen. Today after a reboot, there is a 3-inch wide section of the screen that is faded to the point that you cannot read text that appears on that part of the screen. Can someone help? Thanks,
  • mcijustinb May 27, 2009
    My vertical faded streak is fixed. I do not have an external monitor to connect to.
  • Frank Zhang
    Frank Zhang May 11, 2010
    do you connect to a ext monitor see normall?
    is this vertical lines unstable or fixed there?
SHAMUN
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 15 Answers
  • Posted on Jan 10, 2015
 SHAMUN
Contributor
Level 1:
Welcome Back:
Answers
15
Questions
0
Helped
7490
Points
46
Dear! LCD Fading color or dim display are related with strip. To replace the strip.
Anonymous
Level 3:
Genius:
  • Master 1,550 Answers
  • Posted on May 27, 2009
Anonymous
Master
Level 3:
Genius:
Answers
1550
Questions
Helped
450969
Points
4209
This thing happened in my laptop also i got green screen fully
then when i hit it behind the screen it was gone but comes many times then again i would hit
later on the screen was completly lost then had to replace the screen
yous is a starting period so go to a nearby computer service and fix the screen
2answers
Vertical lines in my laptop screen
Have you tried hooking it up to an external monitor?
This would ensure that it's the screen and not the video card..
If you do that and you receive a good picture then it could be something as simple as a loose video cable. Or it could also mean something like a bad video card or the expensive one, a bad screen.
I had the same problem - sent it in to Acer and they replaced the LCD for 500 bucks!
the lcd (liquid crystal display) is damaged at this time, nor the inverter, that is of course inside of your pc, im afraid you need to send this to a repair shop
cheers
if this line is there during boot up then it is a monitor problem usually. but if it is not then it is a problem with your windows files. you could try reinstalling your windows from the disks you were given with it? otherwise i will look into it. email me if you need more help. [email protected]
thanks
matt
My understanding is that you have 2 laptops with the same problem, if that is the case, you need to replace the lcd. When you have lines on lcd's, that is a sign of a bad lcd.
4helpful
There can be 3 possible reasons for this
1)Screen connector cable is loose. You can try to re-seat it and see if works.
2)display card problem. Connect your laptop to an external monitor and see if the problem persists. If it does not then
3)You will need to get a replacement LCD screen.
Hope this helps!
thats monitor problem dude, better go to the nearest repair center of your toshiba to assist you bout this problem.
1helpful
2answers
Check it on External monitor prior to replacing the screen.. If the problems there as well its not the screen..
2answers
you could try and download a new display driver from here http://h10025.www1.hp.com/ewfrf/wc/product?cc=mx&lc=en&dlc=es&product=499234 if that dosent help Id imagine it is the screen that is at fault.
2answers
Although it could be a screen problem, it is more likely either a loose connection on the inside of the LCD or the video inverter itself which is a board that the LCD attaches to before going to the motherboard. Try hooking it up to an external monitor and if it doesn't do it on that, then we know its not the video card / video output. After that it would be what I spoke of above.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
