Most cell phones don't allow you to control the intensity of the vibration... you can only turn it on or off. However, if you get a rubber case for the phone that might help, because it will absorb some of the vibration.
Check the settings for the vibrate mode.
Have you put the phone on 'Silent'?
Go into Settings,
Go to Sounds and Vibrations.
Turn 'Sound mode' to Sound.
Turn 'Vibrate while ringing' to on. (Move the dot right).
Turn 'Vibration intensity' to a higher setting, (Move the dot right).
Scroll down to 'Do not disturb'. Turn off. (Slide the dot left).
go to settings and look for "sound and notifications" or "sound". it should be under device. then once inside you can toggle or slide volume on or off and also dont forget the vibration intensity.and other sounds option.
you can turn your volume down which will then only work the vibrate motor or in settings go to "sound" change sound mode to either mute or vibrate instead of sound. you can set vibration intensity to low for notifications. also under "ring and notifications" change your notification tone silent at the top of the list.
When you go to settings and set the ringtone for messages and click for vibrate while message enter ensure to hit save before closing the page. This should ensure the phone vibrates when message enters the phone. Although the only other reason why it won't vibrate is if the ******** is bad but if the phone vibrates when call comes in then this is not the problem just save the settings after it has been set. Hope this solution has been helpful?
Adjust the volume of the key tones In Idle mode, press [up /down] and adjust the key tone volume.
Adjust the vibration intensity on the touch screen You can adjust the intensity of the vibration when you tap the phone screen. 1. In Idle mode, press [up /down]. 2. Select Vibration and adjust the intensity of the vibration.
You can change the touch screen vibration settings: press -Menu -Settings -Phone Press Vibration Feedback Set the desired Vibration Intensity setting Press Save to keep the Vibration Feedback settings
