My camera has not been loading film and my dx contacts are one of my last possible suspects. (have changed the batteries and double checked my film --- Film speed index set to DX and film is dx coded)
If you think the contacts are dirty or oxidised, you could try to clean them with a cotton swap and a prop of contact oil. But be sure you can remove all the oil you apply.
Be aware to move the contacts as little as possible. You are allowed to pus them in, but move them sideways can cause them to lose the correct position or worse they can be broken.
It is great to see, Nikon USA, still has lots of manuals of the elder SLR camera's
SOURCE: Film speed override?
Press and hold the ISO button on the top left and rotate the command dial on the right until the film speed appears on the display. Release the ISO button and the speed is set.
In case your instructor hasn't told you, IR light is just below visible light on the spectrum and has a longer wavelength. Therefore, IR light will focus behind the film plane for a given setting. I.e., if you preset the lens to focus at 10 feet, the IR light will focus at a shorter distance. Unless your lens has a distance mark for IR, I would limit my shooting to longer distances and smaller f-stops to use the depth-of -field to compensate. When you are in focus for IR, the image in your viewfinder will be out of focus. The closer you are to the subject, the more out of focus the image will appear at the correct focus setting.
SOURCE: Nikon F60 Film rewind uncoded film help
It sounds to me as if the film has broke inside the camera. For it to have no DX coding on, I can guess it was a very old film, or it was a hand-wound cartridge. both are likely to cause issues.
