Oven light won't turn off
SOURCE: viking oven won't turn on
I had same problem (twice) with my Viking dual fuel range. In my case a relay that supplies power to the oven heating elements failed. The convection fan would run. The elements were warm to the touch. If you have a free standing range, it may be that relay (part number PM010026) which is located in the front of the stove. Remove a long narrow stainless steel panel (1 screw each side) located under where the door hinges. You can hear the relay click when you turn up the oven thermostat. That will help you locate the relay.
Note: Viking does not sell parts. You have to find their parts distributor for your part of the country.
SOURCE: Viking Double Electric Oven VEDO127T
Probably a faulty heater element, some ovens have more than one element in the compartment, so it is possible you only have part heat.
SOURCE: I have electric double oven VEDO275SS by Viking
you need to have a new thermostat fitted or the old one re callibrated if possible
SOURCE: can't put the door back on VIKING oven
should be a clip on each side of the door. hold them in as you slide the door back on.
