SOURCE: model 596.73502203 Making intermittant buzzing sound.
I believe that your refrigerator may need a new 12002495 or 1184282 Adaptive Defrost Control You can find it inside the fresh food section and behind the controls for temperature. Not sure about the buzzing sound yet but the moisture and thawing of the frozen food points to a defrost problem. Need you to unplug and have a look at the adaptive defrost control. Would not hurt to open the back panel in the rear of freezer and defrost if needed and need someone to check the defrost heater and defrost thermostat. Sea Breeze
Testimonial: "Too early to tell if it is the fix but it gives me a place to start. Very hard to pinpoint the source of the buzzing. "
SOURCE: My GE refrigerator/freezer makes a buzz sound for
it's in the control board relay,the board needs replacement,the catch voltage for the relay is weak
SOURCE: Loud buzzing sound. warm fridge and freezer
Could not find info for the model listed could it be PFS22SBASS...any way the most common reason for your issue is the main motherboard part #WR55X10942
prices vary $180 - $200. The circuit that operates the compressor is most likely at fault. Most boards are located at rear of unit lower right, it controls all refer functions. Not hard to instal,l but due to the cost most electrical parts bought are not returnable.
Ric
SOURCE: Admiral refridgerator model lsd2615hez is
what you are hearing is the compresor trying to start . and can not so the over load is shutting down . and when it cools it will try again .. you need to replace the starting device on the compressor .cost about 80.00 parts .. most models . some are more. and the melting is caused by no comp runing .. this is a very common problem .. hope this helps mm feed back pls .
SOURCE: French door refrigerator with bottom
If you are hearing a clicking or buzzing then check out the last two tips.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
